Author Topic: TT lower arms and geometry changes  (Read 20839 times)
Offline Carrera2RS
« on: May 01, 2011, 04:20:27 pm »
Chaps, I have done some measuring and I have found the wheel position is notably different with longer bottom arms
Roughly adding 1 degree of negative camber will have the following effects :
Tyre outer edge at the top of the arch will move out by approx 3mm  an 14mm at the bottom. The track will increase by 18mm (9mm a side) , the front ride height will drop by 5mm.
Adding 1.5 degress of neg (circa 2 degrees total) :
Tyre outer edge at the top of the arch will move out by approx 5mm  an 21mm at the bottom. The track will increase by 26mm (13mm a side) , the front ride height will drop by 7.5mm.
The thread on the control arms is sufficient to cope as the track rod ends will neat to be wound out by a similar amount to the track.
I will see if I can purchase ET50 8 x 18's as the wheel does touch the inner arch occasionally under hard cornering and encountering a bump mid corner. I have ET45 8x18's currently
With circa 2 degrees of neg with ET50's I will be running a front track increase of circa 24mm, 12mm a side  :wink:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: TT lower arms and geometry changes
« Reply #1 on: May 01, 2011, 05:49:43 pm »
and i'm running -2,3 degree of negative camber front, maybe that's why my ET48 8,5x19" with 235/35-19" hits occationally  :laugh:
Over the top mod list ;o)
Offline Carrera2RS
« Reply #2 on: May 01, 2011, 05:54:51 pm »
at -2.3 degrees, if I read correctly your wheel upper edge will be some 3(offset)+say8(5mm tyre per side and 1" strech)+5 (if lowered and adding 1.5 degrees neg)
So probably some 16mm out at the upper edge !
  • -Given: 243
  • -Receive: 154
« Reply #3 on: May 01, 2011, 06:06:15 pm »
I deffo have to do something to my inner fenders, with this and my 10mm wider front fenders the inner fenders aren't sitting right.  :sad1:
Offline Carrera2RS
« Reply #4 on: May 02, 2011, 06:46:14 am »
Sounds like you should have plenty of clearance with 10mm extra width. I had no problems running stock bottom arms, 225/40 18's on 8x18 et 45. the will place the outer wheel edge 11mm further out and tyre probably 8-9mm.
My ride heights are now 338F, 323R. They were 335F, 323R before. I was targeting 340F, 325R, they seem to have settled
  • -Given: 243
  • -Receive: 154
« Reply #5 on: May 02, 2011, 07:19:23 am »
the clearance is there, the trouble is the stock inner fenders doesn'r "rest" in the wider fenders and as such are getting "adjusted" by the tyres  :wink:
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: May 02, 2011, 10:26:02 am »
I dont seem to get any arch clearance issue after fitting the TT arms.  Maybe the vRS has a slightly wider front.  The issue I do have is the WALK combined with the TT arms has given me too much caster and the wheels are much closer to the front of the arch than the rear.  I have modded the WALK and managed to pull the subframe back slightly, but I may go back to the standard consoles with some superpro bushes.
What caster are you two running?  Mine is around 9degs 15 mins.  I would like it to be around 8degs 15mins.
Follow AKS tuning on Facebook
Offline 56OctyVRS
  • -Receive: 72
« Reply #7 on: May 02, 2011, 10:30:25 am »
I was thinking of doing this to my octy but I think I will just stick to normal superpro/powerflex console bushes and not fit the TT control arms.
  • -Given: 243
  • -Receive: 154
« Reply #8 on: May 02, 2011, 10:42:24 am »
Mine with WALK and TT mk2 lower control arms is set at 8,3(4-8)'
http://www.mk5golfgti.co.uk/forum/index.php/topic,7823.msg246912.html#msg246912
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: May 02, 2011, 07:26:41 pm »
I will mod the WALK some more then to get the wheels back where I want them.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #10 on: May 02, 2011, 07:51:12 pm »
Alex, what's wrong with more caster? I'd like to have even more !!
 :wink:
"You get what you pay for."
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: May 03, 2011, 11:47:37 am »
Can someone tell me, if the S3 hubs and wishbones make the track wider??? I seem to be getting some banging from the front when I turn the wheels but it doesn't happen every time? I think the driveshafts outer joints are not seating properly? so when they are turned they are coming apart then going back in when straightened up.
I have checked every thing for loose bolts and cannot find anything :sad1: I usually look at the drop link has they are the most common to make noises.
Darren
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #12 on: May 03, 2011, 11:56:21 am »
I'd wonder if the track is wider with the S3 hubs.
I've fitted them for a week and couldn't see anything different.
  • -Given: 243
  • -Receive: 154
« Reply #13 on: May 03, 2011, 12:13:51 pm »
Darren
I doubt it. if you had trouble with the driveshafts i wouldn't be able to drive with the TT arms  :scared:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #14 on: May 03, 2011, 12:47:04 pm »
I guess with the TT arms it would be better not to adjust the camber to max.
About - 2° should not be any problem as so many guys have it this way without any issues.
 :wink:
