Author Topic: Removing trim around headunit- any tips?  (Read 2394 times)
Offline Scotsman
  • -Given: 32
« on: May 01, 2011, 10:33:40 pm »
Going to fit the Parrot tomorrow - any tips on removing the trim around the headunit itself? I've bought myself a good selection of trim removal tools, but is there a better side to start putting the trim tools into?
Many thanks!
Richard
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Removing trim around headunit- any tips?
« Reply #1 on: May 01, 2011, 10:35:23 pm »
i just found top down worked well for me...
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline roamer1711
« Reply #2 on: May 01, 2011, 10:37:29 pm »
yep top down both sides evenly then watch the clips at the bottom below the aircon.
Went in for a Landy came out with a GTI, mid life crysis? me :-)
« Reply #3 on: May 02, 2011, 12:25:47 am »
Make sure you read the head unit removal guide. You can't just pull off the trim around the HU - there's two screws securing it in place behind the vent.
Offline Scotsman
  • -Given: 32
« Reply #4 on: May 02, 2011, 04:58:31 am »
Thanks guys  :happy2:
Couldn't find the head unit removal guide - but found instructions in these threads:
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
http://www.golfgtiforum.co.uk/index.php?topic=40928.0
http://www.vwgolf.net.au/showthread.php?704-DIY-RNS510-Install
Richard.
« Last Edit: May 02, 2011, 05:27:48 am by Scotsman »
Offline alackofspeed
  • -Receive: 24
« Reply #5 on: May 02, 2011, 06:24:15 pm »
I use a plastic bicycle tyre lever, with the end sharpened to fit in the trim gaps. It's softer than the trim, so leaves no marks.
Offline Scotsman
  • -Given: 32
« Reply #6 on: May 02, 2011, 07:36:46 pm »
Good tip  :happy2:
Offline roamer1711
« Reply #7 on: May 02, 2011, 08:42:44 pm »
I got caught using the Bosses Kitchen spatula, cost me a nights silence and then 30 quid for the proper trim tools next time.
