Author Topic: Jacking up ED30  (Read 1218 times)
Offline wagonboy
  • Nov.2007 ED30 dsg reflex silver
Jacking up ED30
« on: May 02, 2011, 05:03:10 pm »
Hi all, can anyone advise if you can trolley jack the car straight up under the welded deep seam ( behind the recessed tear drop marks in the sill ) where the standard jack supplied with the car would go. Or is there an adaptor you have to use when using a trolley jack.  As stated in the heading its an ED30.  Thanks Chris
Offline PDT
  • -Receive: 142
Re: Jacking up ED30
« Reply #1 on: May 02, 2011, 05:13:49 pm »
You can do, there are adaptors available to slot into the top of the jacking pad but a normal trolley jack will do the job, just line up the seam with the cutouts on the jack, some use a piece of wood or rubber on top of the jack.
And use a good axle stand of course :happy2:
Offline alackofspeed
  • -Receive: 24
Re: Jacking up ED30
« Reply #2 on: May 02, 2011, 05:42:26 pm »
I keep an ice hockey puck for use when jacking - it has a slot cut in it, to fit around the sill seam.
It's a very stiff rubber, and helps protect the sill from jack-rash.
Offline wagonboy
Re: Jacking up ED30
« Reply #3 on: May 02, 2011, 06:57:03 pm »
Thanks for quick reply guys. Information greatly appreciated. Just wanted to put front tyres on back and visa versa to keep wear even. Thanks again Chris    :happy2: :happy2:
Offline PDT
  • -Receive: 142
Re: Jacking up ED30
« Reply #4 on: May 02, 2011, 07:30:39 pm »
Hockey puck = great idea :congrats:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Jacking up ED30
« Reply #5 on: May 02, 2011, 07:38:50 pm »
 :happy2: :happy2: :happy2:
Me doing the same as well. Works great, but only when the car isn't lowered too much.
Otherwise most jacks aren't flat enough.
"You get what you pay for."
