Author Topic: Ramp rental  (Read 1927 times)
Offline johnhol78
Ramp rental
« on: May 03, 2011, 02:54:03 pm »
Does anyone know any companies that rent workshop/ramp space per day?
Would really help taking the precat out of my car?
West London/Bucks/Middlesex area
Offline PDT
  • -Receive: 142
Re: Ramp rental
« Reply #1 on: May 03, 2011, 02:59:12 pm »
you can get to all 4 bolts and the 1st lambda sensor by removing the airbox/engine cover. then under the car just remove the 2 bolts that support the hangers and loosen the exhaust sleeve so it slides backwards, 4 bolts for the aluminum cradle piece and then the 2nd lambda. all done quite easily from drive-on ramps.
Re: Ramp rental
« Reply #2 on: May 03, 2011, 03:04:57 pm »
as above its easy on the drive  :smiley:
Offline johnhol78
Re: Ramp rental
« Reply #3 on: May 03, 2011, 03:08:48 pm »
Right the steps to remove 4 bolts and the 1st lambda sensor sound easy enough though the "2 bolts that support the hangers and loosen the exhaust sleeve so it slides backwards, 4 bolts for the aluminum cradle piece and then the 2nd lambda"
Does anyone have pictures of these parts?
Happy to have a go myself on the drive - got axle stands and drive on ramps - even though the front splitter hits it first....
Might jack it up then plave the ramp under the wheel.....then lower onto ramp.
Offline johnhol78
Re: Ramp rental
« Reply #4 on: May 03, 2011, 03:09:29 pm »
Also do I need new gaskets for when I replace the downpipe?
Offline PaulGTI
Re: Ramp rental
« Reply #5 on: May 04, 2011, 07:39:56 pm »
Check this place out mate, they are in Park Royal
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Ramp rental
« Reply #6 on: May 04, 2011, 07:47:40 pm »
What place?
Offline PaulGTI
Re: Ramp rental
« Reply #7 on: May 04, 2011, 07:57:59 pm »
What place?
ooopps forgot to paste the link in
here you go http://www.pitstartgarage.com/
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Ramp rental
« Reply #8 on: May 04, 2011, 08:27:32 pm »
What place?
That is a f'kin good idea.  Shame I live in Aberdeen  :sad1:
Sepang Blue S4 BE Avant
Offline simonp
  • -Receive: 38
Re: Ramp rental
« Reply #9 on: May 04, 2011, 08:53:34 pm »
There's a few of these type places dotted about. A chap I know who's up the top end of the country (Durham way) has used a similar place in his area.
