Author Topic: Tyre warning light illuminated  (Read 2902 times)
Offline Megy_ED30
« on: May 04, 2011, 08:00:50 am »
Hi all,
On my way into work today my tyre warning light came on, when I press the reset button it goes out for maybe half a second and comes back on again.  When I got to work I had a good look around the tyres and dont see any reason the light would be lit up, no obvious flat tyre or (from what I can see) puncture.
Last night I swapped my off side wheels front to back and vice versa, I noticed the different tyres on the left front to back on the near side where the opposite of the off side, so swapped them so they are the same on both sides at the front and at the back.  But did not do anything else other than swap them over.
Is anyone able to give me more information on what could possibly cause this light to illuminate, and how to get rid of it.
Thanks in advance.
07 Plate GTi ED30 DSG - Grey - Standard (but not for long)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Tyre warning light illuminated
« Reply #1 on: May 04, 2011, 08:15:29 am »
Press and hold the button until you get a ding noise, this will reset the system.  :happy2:
Offline Megy_ED30
« Reply #2 on: May 04, 2011, 08:24:40 am »
Thanks,
I just went out and checked all the pressures (all were fine) so tried it again and light was still lit and wouldnt stay off with the button.  Did the unmanly thing and read the manual where it specifically advises you reset the system if you rotate the wheels front to back as there will be a circumference change.  O well, thanks SteveP.
Offline jamma
« Reply #3 on: May 04, 2011, 06:11:55 pm »
Can anyone tell me what the tyres pressures should be? In PSI please?
cheers
Offline alexperkins
  • -Receive: 99
« Reply #4 on: May 04, 2011, 06:12:54 pm »
37.5 PSI
Offline mrbeck
« Reply #5 on: May 04, 2011, 06:13:53 pm »
Should be on a printed label on the inside of your fuel filler cap.  I keep mine at 2.3bar front and rear as per manufacturer's recommendations for my GT Sport.
2008 VW Golf GT Sport TSI 1.4 (170PS)
OEM + Cruise Control (Retrofit), R36 Omanyt 18" Alloys, R32 Rear Lights, VW Polo Stubby Aerial, VW Front & Rear Mud Guards, Team Heko Wind Deflectors, Dubmeister Pressed Plates, ABT Wolfsburg Plate Surrounds, Autoform Boot Liner.
Offline jamma
« Reply #6 on: May 04, 2011, 06:14:24 pm »
37.5 PSI
 :laugh: jeeeeeeeeeeez, thats high. All four tyres?  I just let mine down to 34 but looks like I better pump them up again lol
Offline alexperkins
  • -Receive: 99
« Reply #7 on: May 04, 2011, 06:18:37 pm »
On the ED30 at least thats what the recommended pressure is  :happy2:
Offline jamma
« Reply #8 on: May 04, 2011, 06:26:51 pm »
Yeah but they are twice as heavy  :wink:
Offline alexperkins
  • -Receive: 99
« Reply #9 on: May 04, 2011, 06:28:43 pm »
lol hardly  :laugh:
Offline Homer
« Reply #10 on: May 04, 2011, 07:38:41 pm »
its 35 PSI for the standard GTI
Offline jamma
« Reply #11 on: May 04, 2011, 07:43:00 pm »
Ah thanks. As I thought , the ED30 is a lot more lardy  :signLOL:
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #12 on: May 04, 2011, 07:44:12 pm »
42psi for an R32!
Offline jamma
« Reply #13 on: May 04, 2011, 07:50:07 pm »
42psi for an R32!
wow . my 911 was 44 though
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #14 on: May 04, 2011, 08:45:24 pm »
See, the more sporting the car the higher the psi... :booty:
Diesel Daily Hack.
