Author Topic: Bluefin Stage 2  (Read 18103 times)
Saint Steve
Re: Bluefin Stage 2
« Reply #45 on: May 11, 2011, 08:54:22 pm »
Cheers Stu...
Just back from some logs of the leafy lanes of Corhampton.. :chicken:.
Superchips have ever so slightly lowered the boost request levels.
The car now feels more progressive, rather then having aggressive "spike" feel.
As my backside dyno felt on 1st thoughts, rail pressures are now requesting and receiving within safer tolerences.
Timing is alot better, having done several runs, and only once hit -4.5 very briefly, but now i have lots of Zero's in the timing columes.Much happier, in the knowledge im not doing any potential harm to the engine..
Fuel filter will be inspected as cars done 57k and never changed..
Sorry about the grids being out of position :sad1:
I will post the logs but they may be abit out of sync..
Runs in 3rd.......
Group 2    Group 20 -    Group 20    Group 20    Group 20    Group 114    Group 115   Group 115   Group 115   Group 230   Group 230
Intake Air    Cylinder 1 Ignition - Angle Delay   Cylinder 2 Ignition - Angle Delay   Cylinder 3 Ignition - Angle Delay   Cylinder 4 Ignition - Angle Delay   W'stgate   Engine Spe   Boost Pres   Boost Pres   Rail Pres   Rail Pres
g/s   °KW   °KW   °KW   °KW   0%   /min   mbar spec   mbar actual   bar spec   bar act
25.56   0   0   0   0   0   2360   610   1080   77.93   76.63
43.47   0   0   0   0   20.4   2000   1670   1140   90.69   90.2
69.86   -1.5   0   -1.5   0   72.5   2240   2280   1370   102.74   101.71
120.89   -1.5   0   -1.5   -1.5   94.9   2600   2300   1780   109.65   109.9
176.81   -1.5   0   -1.5   -3   64.7   3280   2290   2560   109.99   104.6
152.92   -0.8   0   -0.8   -2.3   49   3720   2250   2230   109.99   107.03
186.81   0   0   0   -1.5   50.2   4240   2300   2260   109.99   109.6
198.19   0   0   0   -0.8   53.3   4760   2300   2320   109.99   98.19
218.78   0   0   0   0   57.6   5240   2300   2300   109.99   107.1
237.5   0   0   0   -1.5   63.5   5760   2290   2340   109.99   109.56
234.42   0   0   -1.5   -1.5   63.9   6200   2180   2300   109.99   110.61
183.53   -1.5   0   -3   -0.8   59.2   6600   2000   2220   109.99   113.63
35.92   0   0   0   0   86.3   1720   1620   1130   89.36   89.17
45.25   0   0   0   0   90.2   1840   1700   1250   100.26   100.39
57.42   0   -1.5   -1.5   0   93.3   2000   2200   1410   109.1   109.18
74.06   0   -1.5   -1.5   -1.5   94.9   2160   2260   1600   109.98   110.28
102.03   0   -1.5   -1.5   -1.5   94.9   2400   2270   1930   109.99   109.91
130.67   0   -1.5   -0.8   -1.5   67.1   2720   2310   2400   109.99   106.27
125.64   0   -0.8   -2.3   -0.8   54.1   3000   2300   2440   109.99   109.37
135.69   0   -0.8   -2.3   -2.3   50.2   3280   2260   2280   109.99   110.64
152.42   0   -0.8   -2.3   -2.3   49   3560   2230   2230   109.99   110.57
161.67   0   0   -1.5   -2.3   49   3800   2230   2220   109.99   109.67
165.92   0   0   -1.5   -1.5   49.4   4080   2260   2220   109.99   111.76
177.75   0   0   -1.5   -1.5   50.6   4360   2290   2250   109.99   108.2
190.22   0   0   -1.5   -1.5   53.3   4640   2290   2240   109.99   109.5
193.08   0   0   -0.8   -1.5   52.9   4880   2290   2280   109.99   108.69
202.97   0   -1.5   0   -0.8   53.7   5120   2290   2250   109.99   110.92
212.72   0   -1.5   0   -1.5   55.3   5360   2290   2250   109.99   109.42
222.64   0   -1.5   0   -3   56.5   5600   2290   2250   109.99   110.61
229.86   0   -0.8   0   -3   60.8   5760   2290   2310   109.99   109.09
225.42   -1.5   -0.8   0   -3   58.4   5960   2210   2300   109.99   110.36
222.06   -1.5   0   0   -2.3   59.2   6160   2120   2250   109.99   109.86
210.11   -1.5   0   0   -2.3   51.4   6320   1990   2090   109.99   109.32
Run in 4th
Group 20   Group 20    Group 20   Group 20   Group 102   Group 115   Group 115   Group 230    Group 230    Group 230
Cylinder 1    Cylinder 2    Cylinder 3   Cylinder 4   Engine Spe   Boost Pres   Boost Pres   Rail Pres   Rail Pres   Rail Pres
°KW   °KW   °KW   °KW   /min   mbar spec   mbar act   bar Spec   bar Act   bar Diff.
0   0   0   0   1680   1050   1080   78.38   78.87   -0.49
0   0   0   0   1760   1460   1130   85.64   85.95   -0.31
0   0   0   0   1840   1530   1220   92.59   92.27   0.31
0   0   0   0   1920   1670   1300   100.28   100.36   -0.08
-3   0   -3   0   2000   1730   1380   108   108.44   -0.45
-3   0   -4.5   0   2120   1690   1460   109.86   110.04   -0.18
-3   0   -4.5   0   2200   1680   1550   109.98   109.44   0.54
-3   0   -4.5   -1.5   2320   1630   1630   109.99   110.64   -0.65
-3   0   -4.5   -3   2440   1630   1680   109.99   110.25   -0.26
-3.8   0   -4.5   -3   2560   1770   1700   109.99   109.17   0.82
-3.8   0   -3.8   -3   2720   1950   1840   109.99   110.66   -0.67
-3.8   0   -3.8   -3   2840   2190   2010   109.99   109.93   0.06
-3.8   0   -3.8   -3   3040   2270   2320   109.99   106.19   3.8
-3.8   0   -3.8   -2.3   3240   2250   2330   109.99   99.35   10.64
-3   0   -3   -2.3   3400   2230   2220   109.99   108.14   1.85
-3   0   -3   -2.3   3560   2220   2230   109.99   109.56   0.43
-3   0   -3   -2.3   3760   2220   2200   109.99   110.81   -0.82
-3   0   -3   -2.3   3920   2230   2200   109.99   110.77   -0.78
-3   0   -3   -1.5   4120   2250   2220   109.99   109.37   0.62
-2.3   0   -2.3   -0.8   4320   2270   2230   109.99   109.49   0.5
-1.5   0   -1.5   0   4480   2290   2280   109.99   106.83   3.16
-1.5   0   -1.5   0   4680   2270   2240   109.99   101.56   8.43
-0.8   0   -0.8   0   4840   2280   2260   109.99   110.43   -0.44
0   0   0   0   5000   2280   2240   109.99   109.12   0.87
-1.5   0   0   -1.5   5160   2270   2260   109.99   108.16   1.83
-1.5   0   0   -1.5   5320   2280   2250   109.99   108.15   1.84
-1.5   0   0   -1.5   5440   2280   2250   109.99   102.25   7.74
-1.5   0   0   -1.5   5600   2280   2240   109.99   112.73   -2.74
-0.8   0   0   -0.8   5720   2270   2230   109.99   112.56   -2.57
0   0   0   0   5880   2240   2250   109.99   111.33   -1.34
0   0   0   0   6040   2190   2210   109.99   109.62   0.37
0   0   0   0   6120   2180   2180   109.99   111.33   -1.34
0   0   0   0   6280   2190   2220   109.99   109.6   0.39
0   0   -1.5   0   6400   2190   2250   109.99   110.24   -0.25
 :smiley:
« Last Edit: May 11, 2011, 08:58:14 pm by Saint Steve »
Saint Steve
Re: Bluefin Stage 2
« Reply #46 on: May 11, 2011, 09:29:02 pm »
Ive also emailed Dave (PDT) the logs tonight, so he can draw his valued opinion on this.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Bluefin Stage 2
« Reply #47 on: May 11, 2011, 10:37:02 pm »
I still think you are mitigating the problem Steve and not fixing it.  If the shaft seal has failed on your fuel pump then it will likely be emptying fuel into the engine oil which won't do your engine any good.
A new pump is probably circa £130 so not the end of the world compared to many parts.
Stu...
Saint Steve
Re: Bluefin Stage 2
« Reply #48 on: May 12, 2011, 03:05:21 pm »
My oil level drops Stu , not raises, and doesnt smell of any Super unleaded  :signLOL:
Brand new pump would no doubt cure to an extent, but only if i feel all other potential posibilities into low fuel pressure have been ruled out.
Fuel filter has never been off, so thats a 1st place for me to double check.
Superchips have responded, and looks like this isnt the 1st case....From Email "quote"
Morning Steve,
Glad to see it is running well again, we have our solution. The new remap has reduced filling tables (boost), we have seen other cars from time to time that struggle with the standard Stage 2 who require this. The logs now show all is as it should be, I would advise you stick with this now.
Regards,
 Jo. Superchips
Once again , S.C's responce has been superb in all this.  :happy2:
« Last Edit: May 12, 2011, 03:07:38 pm by Saint Steve »
Offline heavyd
  • -Receive: 29
Re: Bluefin Stage 2
« Reply #49 on: May 12, 2011, 03:47:52 pm »
I'm not suprised it struggles if its using the same boost levels as a stage 3 file does but without the petrol :laugh:
At least you got it sorted :happy2:
Offline liver
Re: Bluefin Stage 2
« Reply #50 on: May 13, 2011, 02:00:40 pm »
i emailed bluefin today stating my boost figures and explaining the dip in power also showing them my graph
here is there response
Hi Mark
These boost figures are low, we would expect the engine to be running 17-18 psi with the stage 2 file. I would suspect that you have a tear in the diaphragm in your dump valve, I suspect this as you turbo is able to produce more boost with the higher load that are achieved using the higher gears and we also come across the issue quite often on the VW Cup cars that we tune.
The dump valve is incorporated into the Turbo, this is on the back of the engine and is most easily accessed from underneath with the vehicle on a ramp.
I hope this helps
Regards
Dave
ive already changed the dumpvalve so it can't be this, but at least i now know i am not boosting correctly. PCV fix will hopefully fix this
im doing some data logging tonight so will post up the results when ive done those, as i wont know what they are showing lol
Offline liver
Re: Bluefin Stage 2
« Reply #51 on: May 16, 2011, 09:49:41 am »
didnt get chance to do any data logging
recieved my bsh stage 1 fix this morning so will try and get that fit asap and hope this is the problem
if not i will try and data log
Offline liver
Re: Bluefin Stage 2
« Reply #52 on: May 18, 2011, 12:00:58 am »
Here's a pic of the broken PCV.
You can see the check valve inside is broken, the circular piece should be centred, but its broken a loose and never creates a seal.
hopefully the car should boost better now, i think im gonna try re-installing the software too, just because the last time it was installed the car had just gone crazy and imobolised itself etc, just for piece of mind really, few days standard then back to stage 2
Offline liver
Re: Bluefin Stage 2
« Reply #53 on: May 19, 2011, 10:21:27 am »
put the car back on the standard map and the car is pretty much boosting the same as it was previously
will try n get logs in standard mode then with the map on to compare
Offline liver
Re: Bluefin Stage 2
« Reply #54 on: May 21, 2011, 06:35:29 pm »
sorted the logging out
here are the logs, remember the car is on the standard map, will also log 2mora when the map is back on to show the differences
   Group A:   '002            Group B:   '106            Group C:   '115
      Engine Speed   Engine Load   Injection   Intake Air Mass      Fuel Rail   Electrical   Electrical   Time      Engine Speed   Engine Load   Boost Pressure   Boost Pressure
   TIME         Timing      TIME   Pressure   Fuel Pump 1   Fuel Pump 2      TIME         (specified)   (actual)
Marker   STAMP    /min    %    ms    g/s   STAMP    bar    %       s   STAMP    /min    %    mbar    mbar
   0.11   2360   121.8   4.08   68.56   0.24   109.4   55.7       655.35   0.01   2360   121.1   1720   1470
   0.51   2520   130.1   4.59   75.44   0.63   109.4   56.9       655.35   0.36   2440   127.1   1740   1590
   0.88   2640   139.1   4.84   81.17   1.02   110.1   57.6       655.35   0.75   2600   137.6   1780   1740
   1.27   2760   144.4   5.1   87.97   1.4   109.4   58.8       655.35   1.14   2720   142.9   1770   1820
   1.66   2920   145.9   5.1   89.97   1.78   110.7   58.8       655.35   1.54   2840   145.9   1760   1830
   2.05   3040   144.4   5.1   91.69   2.17   108.8   59.6       655.35   1.91   3000   144.4   1750   1780
   2.42   3160   143.6   5.36   97.22   2.57   110.1   60.4       655.35   2.3   3120   143.6   1740   1750
   2.81   3320   143.6   5.61   101.42   2.94   109.4   60.8       655.35   2.69   3240   143.6   1730   1740
   3.2   3440   143.6   5.61   105.94   3.33   108.2   61.6       655.35   3.08   3400   142.9   1720   1740
   3.6   3560   143.6   5.61   106.86   3.72   108.8   62       655.35   3.45   3520   143.6   1720   1750
   3.97   3680   139.1   5.36   108.89   4.11   110.7   61.6       655.35   3.84   3640   139.8   1710   1690
   4.36   3800   139.1   5.36   112.97   4.48   108.2   62.4       655.35   4.23   3760   139.8   1700   1700
   4.75   3920   139.1   5.36   115.75   4.88   110.7   63.5       655.35   4.63   3880   139.8   1700   1690
   5.14   4040   139.1   5.36   120.33   5.26   108.8   63.5       655.35   5   4000   139.8   1690   1680
   5.51   4160   139.8   5.61   122.81   5.65   109.4   64.3       655.35   5.39   4120   139.1   1690   1680
   5.9   4240   141.4   5.87   130.92   6.03   110.1   65.1       655.35   5.78   4240   140.6   1690   1680
   6.29   4360   142.1   5.87   133.47   6.42   109.4   65.5       655.35   6.17   4320   141.4   1690   1680
   6.68   4480   142.9   6.12   138.31   6.81   109.4   66.3       655.35   6.54   4440   142.9   1690   1680
   7.06   4560   144.4   6.12   142.22   7.2   108.2   67.5       655.35   6.93   4560   144.4   1680   1670
   7.44   4680   144.4   6.12   144.58   7.58   110.1   67.5       655.35   7.32   4640   144.4   1680   1670
   7.84   4800   143.6   6.12   145.61   7.96   108.8   67.1       655.35   7.71   4760   143.6   1680   1660
   8.23   4880   143.6   6.12   148.58   8.35   110.1   67.8       655.35   8.09   4840   142.9   1670   1680
   8.6   4960   142.1   6.12   150.11   8.74   110.1   68.2       655.35   8.48   4960   141.4   1670   1660
   8.99   5080   142.9   6.12   154.97   9.12   108.8   68.6       655.35   8.87   5040   142.1   1660   1660
   9.38   5160   142.9   6.12   156.56   9.51   108.2   68.6       655.35   9.26   5120   142.1   1630   1670
   9.77   5240   139.8   6.12   154.97   9.9   108.2   69.4       655.35   9.63   5200   141.4   1610   1640
   10.15   5320   136.1   5.87   155.31   10.29   110.1   69.8       655.35   10.02   5280   137.6   1600   1600
   10.54   5400   133.8   5.87   154.11   10.66   112   68.6       655.35   10.41   5360   135.3   1490   1580
   10.93   5440   83.5   3.06   84.83   11.05   113.3   58.8       655.35   10.81   5440   109   1040   1620
   11.32   5520   104.5   4.08   129   11.44   108.8   62.7       655.35   11.18   5520   101.5   1500   1200
   11.69   5600   119.5   5.1   157.89   11.83   108.2   62.7       655.35   11.57   5560   115   1530   1350
   12.08   5600   103   4.34   113.75   12.21   111.4   63.1       655.35   11.96   5640   92.5   1430   1450
   12.47   5680   106.8   4.34   132.25   12.59   109.4   64.7       655.35   12.35   5680   106   1460   1240
   12.86   5760   118.8   5.1   148.44   12.99   105.6   67.8       655.35   12.72   5720   115.8   1310   1360
   13.24   5840   115.8   4.84   139.06   13.38   115.2   63.5       655.35   13.11   5800   120.3   1250   1410
   13.63   5840   78.2   2.81   85.81   13.75   110.1   60       655.35   13.5   5840   78.2   930   1460
   14.02   5920   100.8   4.08   129.97   14.14   105.6   64.3       655.35   13.89   5880   97.7   1290   1170
   14.41   5960   105.3   4.34   136.64   14.53   110.7   65.9       655.35   14.27   5960   103   1440   1210
   14.78   6000   117.3   5.1   157.69   14.92   102.4   69.4       655.35   14.65   6000   112.8   1440   1300
   15.17   6080   130.8   5.87   173.89   15.3   108.8   70.2       655.35   15.05   6080   127.8   1430   1490
   15.56   6160   132.3   5.87   172.5   15.69   110.1   70.2       655.35   15.44   6120   133.1   1420   1520
   15.95   6200   125.6   5.61   165.83   16.08   109.4   69.8       655.35   15.81   6200   127.8   1410   1460
   16.32   6280   121.8   5.36   163.22   16.47   108.2   69.8       655.35   16.2   6280   121.8   1400   1430
   16.71   6360   121.1   5.36   162.78   16.84   109.4   69.8       655.35   16.59   6320   121.1   1380   1410
   17.1   6400   118.8   5.1   160.78   17.23   111.4   70.6       655.35   16.98   6400   119.5   1370   1390
   17.49   6440   116.5   5.36   161.58   17.62   106.2   69.8       655.35   17.35   6440   116.5   1350   1380
   17.87   6520   117.3   5.36   163.64   18.01   110.7   70.2       655.35   17.74   6480   118.8   1350   1370
   18.28   6560   115   5.1   161.31   18.4   112.6   69.8       655.35   18.14   6560   117.3   1340   1350
   18.66   6640   113.5   5.1   160.58   18.79   107.5   69.4       655.35   18.54   6600   113.5   1330   1330
   19.06   6680   112.8   4.84   160.47   19.18   113.9   69.4       655.35   18.91   6640   113.5   1270   1330
   19.43   6720   110.5   4.84   159.61   19.57   113.3   69.4       655.35   19.3   6720   111.3   1250   1300
   19.82   6720   106   4.59   151.58   19.95   114.6   67.8       655.35   19.69   6720   108.3   1200   1260
Saturday   21   May   2011   18:12:42:29760   VCDS Version: Release 10.6.4   Data version: 20110418
1K0 907 115       2.0l R4/4V TFSI  00 0070
   0.2   2320   151.1   5.36   84.36   0.33   109.4   56.5       655.35   0.06   2240   142.9   1850   1830
   0.58   2400   166.2   5.87   90.64   0.72   109.4   58.4       655.35   0.45   2360   163.9   1820   2070
   0.97   2520   160.2   5.87   81.83   1.09   109.4   57.3       655.35   0.84   2520   163.9   1800   2060
   1.36   2640   145.1   5.1   78.22   1.48   110.7   56.5       655.35   1.24   2600   148.9   1790   1860
   1.75   2760   140.6   5.1   82.83   1.87   110.7   56.5       655.35   1.61   2720   141.4   1780   1780
   2.12   2840   140.6   5.1   85.47   2.27   110.1   57.6       655.35   2   2840   141.4   1770   1780
   2.51   2960   141.4   5.36   90.28   2.64   110.1   58.8       655.35   2.39   2920   140.6   1760   1770
   2.9   3080   142.1   5.61   94   3.03   110.1   58.8       655.35   2.78   3040   142.1   1750   1770
   3.29   3160   142.9   5.61   96.97   3.42   109.4   59.2       655.35   3.15   3120   142.9   1740   1750
   3.66   3280   142.1   5.61   101.58   3.81   109.4   59.6       655.35   3.54   3240   142.1   1730   1740
   4.05   3400   142.9   5.61   104.28   4.18   110.1   60       655.35   3.93   3360   143.6   1720   1750
   4.45   3480   141.4   5.61   105.47   4.57   110.1   60.4       655.35   4.32   3440   142.1   1720   1730
   4.84   3560   142.1   5.61   108.75   4.97   109.4   60.4       655.35   4.7   3560   142.1   1710   1730
   5.21   3680   139.8   5.36   109.78   5.35   110.1   60.8       655.35   5.09   3640   140.6   1710   1710
   5.6   3760   136.1   5.36   109.89   5.72   110.7   60.8       655.35   5.48   3760   136.8   1700   1670
   5.99   3880   137.6   5.36   115.22   6.12   110.1   61.6       655.35   5.87   3840   136.8   1690   1680
   6.38   3960   137.6   5.36   116.83   6.51   110.1   61.2       655.35   6.24   3920   137.6   1690   1680
   6.76   4080   138.3   5.36   120.44   6.9   109.4   62.7       655.35   6.63   4040   138.3   1680   1690
   7.14   4160   139.1   5.61   123.83   7.27   107.5   63.1       655.35   7.02   4120   139.1   1680   1690
   7.53   4280   139.1   5.61   125.92   7.66   110.7   63.5       655.35   7.41   4240   139.8   1680   1670
   7.93   4360   139.1   5.61   129.94   8.05   110.7   64.3       655.35   7.79   4320   139.8   1680   1670
   8.3   4480   142.1   5.87   134.42   8.44   109.4   65.1       655.35   8.17   4440   140.6   1680   1670
   8.69   4560   142.1   5.87   139.92   8.81   110.1   66.3       655.35   8.56   4520   142.9   1680   1660
   9.08   4640   141.4   6.12   140.64   9.2   110.1   67.1       655.35   8.96   4640   141.4   1670   1660
   9.47   4760   142.1   6.12   145.22   9.6   110.1   67.1       655.35   9.33   4720   142.1   1670   1660
   9.84   4840   140.6   5.87   145.64   9.99   110.1   67.1       655.35   9.72   4800   141.4   1670   1650
   10.23   4920   139.8   5.87   147.94   10.36   111.4   67.5       655.35   10.11   4920   141.4   1660   1660
   10.62   5000   141.4   5.87   153.78   10.75   108.2   67.8       655.35   10.5   5000   142.1   1660   1670
   11.02   5120   141.4   6.12   152.75   11.14   108.2   67.8       655.35   10.87   5080   141.4   1640   1670
   11.39   5200   139.1   5.87   152.94   11.53   110.7   68.2       655.35   11.27   5160   139.1   1620   1640
   11.78   5280   136.8   5.87   153.17   11.9   109.4   67.8       655.35   11.65   5240   136.8   1600   1600
   12.17   5360   134.6   5.87   155.36   12.29   111.4   68.2       655.35   12.05   5320   135.3   1580   1590
   12.56   5440   135.3   5.87   156.42   12.69   109.4   68.2       655.35   12.42   5400   134.6   1560   1590
   12.94   5520   132.3   5.61   156.03   13.08   110.7   68.2       655.35   12.81   5480   133.1   1550   1560
   13.32   5600   131.6   5.61   156.42   13.45   106.9   68.2       655.35   13.2   5560   131.6   1530   1530
   13.71   5680   129.3   5.61   156.75   13.84   110.7   68.2       655.35   13.59   5640   130.1   1520   1520
   14.11   5760   129.3   5.61   159.47   14.23   109.4   68.2       655.35   13.96   5720   130.1   1500   1510
   14.48   5800   128.6   5.61   158.94   14.62   108.8   68.6       655.35   14.35   5760   128.6   1490   1490
   14.87   5880   127.8   5.36   160.78   14.99   111.4   69       655.35   14.74   5840   126.3   1470   1490
   15.26   5920   127.8   5.61   160.78   15.38   108.2   69       655.35   15.13   5920   126.3   1460   1470
   15.65   5960   126.3   5.36   163.03   15.77   110.7   69       655.35   15.51   5960   126.3   1450   1460
   16.03   6040   125.6   5.36   162.75   16.16   110.1   69       655.35   15.9   6040   125.6   1440   1450
   16.41   6120   122.6   5.36   158.56   16.53   110.7   69       655.35   16.29   6080   122.6   1430   1440
   16.8   6160   121.8   5.36   161.86   16.93   108.8   69.4       655.35   16.68   6160   122.6   1420   1430
   17.19   6200   121.1   5.36   161.89   17.32   110.1   69.4       655.35   17.05   6200   121.8   1410   1420
   17.56   6280   119.5   5.1   161.19   17.71   110.1   69.4       655.35   17.44   6280   120.3   1400   1410
   17.96   6320   118.8   5.36   159.25   18.08   110.7   69.4       655.35   17.83   6320   119.5   1390   1400
   18.35   6400   118   5.36   161.19   18.47   112   69.8       655.35   18.23   6360   117.3   1380   1390
   18.74   6440   118.8   5.36   163.53   18.86   110.7   69.8       655.35   18.6   6400   118   1370   1390
