Author Topic: Bought an RNS510  (Read 1662 times)
Offline DaveR77
    • UK-MKIVS.net
Bought an RNS510
« on: May 05, 2011, 06:39:03 pm »
Just got my RNS510 delivered  :happy2:
I understand I need an aerial adapter, is that correct? If so where do I get one from?
Also, doesn't look like the unit came with the security card, will it work without it?
Finally, are there any install guides around?
Offline alexperkins
  • -Receive: 99
Re: Bought an RNS510
« Reply #1 on: May 05, 2011, 06:50:53 pm »
You will need an aerial adapter
Either eBay or VW, but ensure it is genuine
The part number you will need is 7L6 051 551 and its RRP ex VAT is £24.17
As for the security card, no - you will need to code in order to initialise the unit. Have a look on the unit to see if its got a sticker with a 4 digit number on it as sellers sometimes put this on there.
Install guides...
Theres a really good guide here  :- http://www.vwgolf.net.au/showthread.php?704-DIY-RNS510-Install
You will need to code the car to accept and RNS510 if you dont have an MFD2 at present by enabling 37- Navigation on the CAN installation list
Offline DaveR77
    • UK-MKIVS.net
« Reply #2 on: May 05, 2011, 06:53:49 pm »
ta, got in touch with the seller and the code is on top.
Just found this guide and it mentions different part numbers for the aerial adapters, are there different one?
http://www.r32oc.com/tutorials-guides/18955-rns-510-mfd-install-how-guide-inc-pin-swap.html
Offline alexperkins
  • -Receive: 99
« Reply #3 on: May 05, 2011, 06:57:28 pm »
Ah good. Remember to remove it from the unit and write it down somewhere safe, or its a thieves for the taking
As for the part numbers, use the one I have given you.
The part numbers there refer to different connections mainly used on the earlier GTIs which have a different radio setup, whereas the newer ones (such as yours with a K gateway) have the more modern beige and white connectors with the newer style terminal which the dedicated adapter is for
Plus its important to note that unless the proper adapter is used, AM radio and TMC will not work properly
« Last Edit: May 05, 2011, 07:02:17 pm by alexperkins »
Offline DaveR77
    • UK-MKIVS.net
« Reply #4 on: May 05, 2011, 07:01:58 pm »
will do, i'll get the lead tomorrow.
Did you do the moving wire from pin 2 to 3 thing?
http://www.my-gti.com/1336/cd-changer-audio-sound-quality-problems-after-changing-head-unit
Offline alexperkins
  • -Receive: 99
« Reply #5 on: May 05, 2011, 07:03:14 pm »
If you have a cd changer or an iPod dock on the current HU, then yes youll definately need to swap the 2 to 3 pin over or the sound will be distorted  :happy2:
Offline DaveR77
    • UK-MKIVS.net
« Reply #6 on: May 06, 2011, 09:00:54 am »
Not sure what I have tbh, it's a loose ipod cable in the armrest, not a dock. I'm sure i'll see when I remove the old unit
Offline alexperkins
  • -Receive: 99
« Reply #7 on: May 06, 2011, 11:07:51 am »
Hmm might be an aux lead
Could you change track on the HU or did you have to change it on the iPod?
Offline DaveR77
    • UK-MKIVS.net
« Reply #8 on: May 06, 2011, 11:15:47 am »
Not tried it tbh, only had the car 2 days.
Offline alexperkins
  • -Receive: 99
« Reply #9 on: May 06, 2011, 11:16:43 am »
Ah fair play
With regard to your gateway, just try the RNS and see if itll work as it might save you 100!
« Last Edit: May 06, 2011, 11:21:22 am by alexperkins »
