July 04, 2024, 09:51:02 pm
All Things Mk5
Technical Workshop
30mm Springs & 18x8
Topic: 30mm Springs & 18x8 (Read 1673 times)
rdfcpete
Just look at my post count
-Given: 98
-Receive: 52
30mm Springs & 18x8
May 07, 2011, 02:19:56 pm »
I'm currently on 20mm AP springs. They're superb in their ride comfort and cornering ability, at least for what I'm looking for anyway. I can't fault their performance.
I simply want a slightly lower drop, particularly at the rear.
I'm on 18x8 Turinis.
It's essential that I can use full lock and also have 2/3 passengers in the rear of the car occassionally.
If I drop another 10mm and put 30mm springs on front and rear, will I experience rubbing in the above scenarios or will this be usable?
Pete
RNS-E LED 2012 | Aux-In | AP Coilovers | Hawk HPS Pads | Revo Stage 1+
danishmkvgti
-Given: 243
-Receive: 154
My Ride:
Re: 30mm Springs & 18x8
Reply #1 on:
May 07, 2011, 03:12:29 pm »
Depends???? What ET do you have
Over the top mod list ;o)
rdfcpete
-Given: 98
-Receive: 52
Reply #2 on:
May 07, 2011, 04:41:18 pm »
Sorry Jake! Monkey
The Turinis are ET42+ I believe - ?
Pete
danishmkvgti
-Given: 243
-Receive: 154
My Ride:
Reply #3 on:
May 07, 2011, 04:44:51 pm »
I can't see it being a problem then, again ET 45 to 48 would be better. Mine was very low, 295mm from center to lower part of front fender with no issues, although my rims is 7,5x18 ET 51.
SteveP
-Given: 117
-Receive: 340
Reply #4 on:
May 07, 2011, 06:16:23 pm »
All be it on a Mk6 I had the speedlines with 40mm drop and had no major issues. Just needed to do the normal arch screw mod
rdfcpete
-Given: 98
-Receive: 52
Reply #5 on:
May 07, 2011, 07:30:41 pm »
Thanks both of you
Were they the 40mm H&R springs similar to the 30mm ones you ran on your Ed30 Steve? Ta.
Pete
SteveP
-Given: 117
-Receive: 340
Reply #6 on:
May 07, 2011, 07:31:05 pm »
Very similar.
rdfcpete
-Given: 98
-Receive: 52
Reply #7 on:
May 09, 2011, 09:06:00 pm »
I remember this vaguely, but does the arch screw mod only apply to the front?
I may put 30mm springs on only the rear.
Ta.
Pete
SteveP
-Given: 117
-Receive: 340
Reply #8 on:
May 09, 2011, 09:08:52 pm »
Why would you want to mix the springs
rdfcpete
-Given: 98
-Receive: 52
Reply #9 on:
May 09, 2011, 09:20:21 pm »
Not wise then?
Purely because the rear sits a little high, whereas the front is fine.
Pete
apollo13
-Given: 2
-Receive: 47
Reply #10 on:
May 09, 2011, 09:21:50 pm »
^^ Pete your a nutter!
The spring rates will probably be different mate, not a wise move
rdfcpete
-Given: 98
-Receive: 52
Reply #11 on:
May 09, 2011, 09:23:42 pm »
Even same brand i.e. AP 30mm springs at the rear?
I'm looking at stupid options as I can't justify £500 on some coilovers just for cosmetics
Fair enough re. the spring rate
Cheers.
Pete
All Things Mk5
Technical Workshop
30mm Springs & 18x8
