Author Topic: Eddie-NL's Golf GT Tdi  (Read 46600 times)
ash118118
Re: Eddie-NL's Golf GT Tdi
« Reply #60 on: January 09, 2016, 04:08:54 pm »
Hi Eddie,
Are you still doing VW Retrofits for the VW Golf MK5? If yes then please PM me? I haven't posted yet so seem unable to PM you directly or am I doing something wrong?
Offline Shadowman
« Reply #61 on: October 20, 2016, 08:09:18 am »
Hello Eddie
I have a mk5 gt and I have some problems with my midline cluster and I need to change it .
I found a high line  cluster from a gt ,
Is there a way to see if it will work and be able to transfer the odometer reading as well as the immo code from my old cluster and write them to the new cluster ?
Part numbers maybe ?
Thanks a lot
Sent from my Nexus 6P using Tapatalk
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #62 on: October 21, 2016, 09:28:27 pm »
Hello Eddie
Thanks a lot
where are you?
it is possible to upfrade to a highline
Cluster and Key coding
Location Great Yarmouth
Offline Shadowman
« Reply #63 on: October 21, 2016, 11:18:47 pm »
Hello Eddie
Thanks a lot
where are you?
Can you send me a pm ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #64 on: October 22, 2016, 06:00:13 pm »
Lilucas_R32
« Reply #65 on: February 04, 2018, 01:26:15 am »
Hi there Eddie-NL,
I was reading a post about a guy’s project, and he mentioned you helped him with coding his ABS module. I have basically the same situation. The ABS module on my MK5 R32 went bad, and I replaced it with a new one. Problem is the stock ABS module is a MK60, and the new one is a MK60EC1. I have vcds, but can’t seem to find a way to coding it properly. Is there anything you could do to help me? I have already swapped the front brake lines because they are crossed on the new pump, and also swapped the pins on the ABS module connector using a chart to match the diagram on the new module. I tried to send you a private message, but it didn’t work. Hoping you can at least point me in the right direction. Thank you in advance.
Offline Christiank
  • -Receive: 39
« Reply #66 on: February 04, 2018, 10:05:18 pm »
@Lilucas_R32    - Don't think Ed is on here very much since he sold his Mk5 a while ago.
However PM a scan of your car, then maybe I can help you with that ABS long coding.
Did do this MK60 MK60EC1 swap myself.
Chris. :drinking:
