Author Topic: RCD510 - DAB Installed. Aerial help  (Read 4658 times)
Offline james
« on: May 07, 2011, 06:43:48 pm »
I have installed the rcd510 and noticed the connections where different for the FM/AM /DAB.  So i put the brown wire on the FM2 connection.  I then removed the casing of the connecition and stuck it on the dab connection.
As soon below.
Where do i buy a dab aerial as the dab radio is poor,  cuts in and out and it is fine in my old mans car.
Offline mortygttdi
  • -Receive: 146
Re: RCD510 - DAB Installed. Aerial help
« Reply #1 on: May 08, 2011, 11:47:22 am »
Try one of these, also take that connection out asap, has the fm1 + 2 have a small current going through them and will damage the DAB module.
http://shop.ebay.co.uk/i.html?_nkw=car+dab+aerial&_frs=1&_trksid=p3286.c0.m359
Darren :happy2:
« Last Edit: May 08, 2011, 11:54:10 am by mortygttdi »
Offline james
« Reply #2 on: May 08, 2011, 12:40:43 pm »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: May 08, 2011, 01:19:56 pm »
Remember you'll need a cable from the antenna to the HU.
Stu...
Offline james
« Reply #4 on: May 08, 2011, 02:00:58 pm »
yea that is fine, i dont mine taking my dash apart,  will it fit ok?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: May 08, 2011, 03:01:22 pm »
The point I was making is that if you order the antenna you linked, it doesn't look like it includes the cable.
Stu...
Offline james
« Reply #6 on: May 08, 2011, 04:23:25 pm »
oh sorry,  thanks for the heads up.
