Author Topic: Well the golf is fixed finally  (Read 22142 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Well the golf goes up in smoke yet a 3rd time***ITS DONE***
« Reply #60 on: May 20, 2011, 05:29:29 pm »
So what's the spec/figures now? Nice...
Diesel Daily Hack.
« Reply #61 on: May 20, 2011, 06:34:25 pm »
Jet read this through now Daz!  :surprised:
Glad it's now sorted and hopefully your smoking smiling right now!  :driver:
Offline mortygttdi
  • -Receive: 146
« Reply #62 on: May 20, 2011, 06:46:02 pm »
Cheers Nath but no smiles yet, apparently the turbo has an abnormal whistling so Steve is not letting it go until its sorted, will have another turbo on Monday afternoon :sad1:
Low, it might sound strange but I'm not after figures I just want my car back, and the engine to last so I have asked Steve to keep it conservative but strong :happy2: Should be around the 220bhp - 370lb ft??? est, Ill get down to Paul's at RS Tuning when I get chance just to confirm.
Darren
Offline apollo13
  • -Receive: 47
« Reply #63 on: May 20, 2011, 06:51:21 pm »
Not having much luck at all mate!
Lets hope when it's finally done all the agro will be worth it  :happy2:
Offline PDT
  • -Receive: 142
« Reply #64 on: May 20, 2011, 07:55:02 pm »
What clutch /exhaust is on it? Was it dyno tuned?
Offline mortygttdi
  • -Receive: 146
« Reply #65 on: May 21, 2011, 01:58:25 pm »
PDT I was scared the clutch would be fubared but apparently its fine and is an uprated one from what Steve was saying, the exhaust is a standard GTI but with no cat...this may change very soon?
What would your guestimate be buddy your input would be appreciated :happy2:
Darren
Offline mortygttdi
  • -Receive: 146
Re: Well the golf goes up in smoke yet a 3rd time***Dave(PDT) needed***
« Reply #66 on: June 18, 2011, 09:15:49 pm »
Well got the car back last week and felt fine for a couple of days, not giving it hell but the car just didn't feel like it used, although it is fast,
I was going to work yesterday and put my foot down a little bit more than previous, I got to around 4k rpm and the car went into limp mode car otherwise was running smooth as but with no turbo??? Any way I pulled over just before getting to work and turned the car off and back on, and it was back to full turbo.
Here is the scan for the fault, no engine light by the way.
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FM    HW: 028 101 190 3
   Component: R4 2,0L EDC G000SG  6179
   Revision: 12345678    Serial number: VWZ7Z0E1377576
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 73EF31EC6B33
2 Faults Found:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
            P0234 - 000 -  -
             Freeze Frame:
                    RPM: 4410 /min
                    Torque: 292.0 Nm
                    Speed: 111.0 km/h
                    Load: 100.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 00001000
                    Absolute Pres.: 1907.4 mbar
                    Absolute Pres.: 2590.8 mbar
16485 - Mass Air Flow Sensor (G70): Implausible Signal
            P0101 - 000 -  -
             Freeze Frame:
                    RPM: 1680 /min
                    Torque: 0.0 Nm
                    Speed: 58.0 km/h
                    Load: 0.0 %
                    Duty Cycle: 96.8 %
                    Bin. Bits: 00001000
                    Mass Air / Rev.: 285.0 mg/str
                    Mass Air / Rev.: 610.0 mg/str
Readiness: 0 0 0 0 0
I'm going to speak to the garage on Monday and get my money back for the map and ill be then going down to Pauls @ RS Tuning.
Darren
Re: Well the golf goes up in smoke yet a 3rd time***Dave(PDT)***
« Reply #67 on: June 18, 2011, 10:11:40 pm »
 :sad1:
Not good news mate, hope you get it sorted ASAP!!!
Offline PDT
  • -Receive: 142
« Reply #68 on: June 19, 2011, 12:59:07 am »
Why does my name appear in the thread title?
« Reply #69 on: June 19, 2011, 01:05:53 am »
I think Darren is after your help Dave.....
« Reply #70 on: June 19, 2011, 01:12:00 am »
Sorry to hear this Darren :(
Offline PDT
  • -Receive: 142
« Reply #71 on: June 19, 2011, 08:46:25 am »
What sort of power was it making when mapped? Why were you taking it easy with RPM/throttle?
Offline mortygttdi
  • -Receive: 146
« Reply #72 on: June 19, 2011, 11:20:38 am »
Dave sorry mate thought I would try and get your attention but needed to document in here just in case it helps any one else :happy2:
Basically the guy who fitted the turbo and applied the map told me to run it in? so I thought I would take it steady and make sure I didn't damage anything. I've just spent £2.5k I don't want it to go again.... :scared:
Any way my mate is best friends with Paul @ RS Tuning so I'm going to call down there tomorrow and get it live mapped, has the map on it is just what has come from S/C modded to take the cat delete into account.
I'm sure you can feel the turbo stalling if your feathering the throttle?
Also today coming home from work on the m/way I was only doing 70/80mph and went to put my foot down in 6th and there was nothing there? I had to drive for another 2-3 mile and then pull over to turn it off and back on? then it was like poo off a shovel.
Darren
« Reply #73 on: June 19, 2011, 11:31:08 am »
Let's hope its the map you have on now that is causing the issues mate
Offline PDT
  • -Receive: 142
« Reply #74 on: June 19, 2011, 07:03:04 pm »
Running a turbo in :stupid:
When we do a stage 3 hybrid conversion on these engines we turn the lot round from a stock car to mapped on the Dyno in 3 days, turbos have no contact parts or interference bearings so there is no running in required.
More like 'take it easy to run it in' = it goes into limp mode when given any load so take it easy for a while so the car is plenty far away from us when it a goes tits up.
