Author Topic: can anyone interpret these alignment settings?  (Read 1607 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: May 11, 2011, 09:28:42 am »
Hi will try scan and post actual print out later but for now -
Left Front -
-1.47 camber
8.36 caster
0.05 toe
Right front - -1.33 camber
8.23 caster
0.05 toe
left rear -1.44 and -1.42 camber
0.05 and 0.06 toe
thrust angle -0.01
Offline adamf
Re: can anyone interpret these alignment settings?
« Reply #1 on: May 11, 2011, 10:01:25 am »
I don't understand.. what do you need to know?..
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: May 11, 2011, 01:53:22 pm »
well whether it is set up well, would you be happy with these settings? I dont understand about the geometry aspect at all so it is just gibberish to me.
Thanks.
Offline adamf
« Reply #3 on: May 11, 2011, 02:19:44 pm »
Unless someone here knows the correct tolerances for a golf it would prob be easier to scan the printout. I'm not sure what the corrects ones are. Does your printout show them being green?..
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #4 on: May 11, 2011, 03:24:16 pm »
will try scan printout tonight, ta
Offline prf
« Reply #5 on: May 11, 2011, 07:22:47 pm »
Assuming it's a Mk 5 GTI, then Front Camber is OUT of specification. Front Caster is OUT of spec on the left, and only just IN on the right. The Front Toe, however, is safely within spec. The Rear looks all to be within spec.  The 'Toe' is generally the 'killer' parameter for uneven tyre wear, so yours looks OK.  However, it would be worth a visit to a reliable tyre/alignment outlet to get the front Camber and Caster adjusted back into specification.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #6 on: May 11, 2011, 10:11:59 pm »
thanks
Offline Carrera2RS
« Reply #7 on: May 11, 2011, 11:28:14 pm »
This is worth a read
http://www.nyracer.com/overunder.htm
If you are happy (I'm not) with stock GTi suspension then set up to factory settings. If not you can tweak and go out of 'spec'
