Author Topic: Changing steering wheel  (Read 1764 times)
GTIStevie
« on: May 11, 2011, 03:58:29 pm »
Right im looking to change my steering wheel to the MK6 wheel with MF buttons, currently have a 2005 with no buttons and I think it's the midline display. Anyone know what I will need to make the MK6 wheel work and if the airbags are compatible.
Any help and part number would be great and if anyone knows a good place near Aberdeen to have it coded in would be appreciated.
Re: Changing steering wheel
« Reply #1 on: May 11, 2011, 04:12:02 pm »
you will need to get  The steering module and the slip ring to get it to work..the air bags are different as far as i know;send eddie nl or Darren(mortygttdi) who will know more about this than i will
It is a good mod,Darron did mine have a look in my build thread
Offline big al
« Reply #2 on: May 11, 2011, 07:54:23 pm »
If you have midline you will never get all the buttons working. Only the volume and mpg indicator.
The airbags are different on the mk5 to mk6. You will need a version c slipring and the module.
If you want the whole wheel to work you will need a highline unit fitting which isn't very cheap.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: May 11, 2011, 08:12:37 pm »
A mk6 wheel won't fully work unless you have a Highline cluster with white back lighting.
However even without a red highline you can still change CD tracks
Cluster and Key coding
Location Great Yarmouth
GTIStevie
« Reply #4 on: May 11, 2011, 08:34:37 pm »
Ok so if I get the steering wheel and airbag, I will also need a version c slip ring and module and I will only get volume, track select and mpg data..will it need to be coded to work and would anyone have a rough idea of part numbers for these parts.
Is I a big task to hook it all up or is it better to get a pro to do it??
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
GTIStevie
« Reply #6 on: May 11, 2011, 09:02:10 pm »
Offline apollo13
  • -Receive: 47
« Reply #7 on: May 11, 2011, 09:48:31 pm »
Ed I have a highline cluster with white backlighting and my MK6 wheel doesn't fully work  :signLOL:
