Author Topic: Door Mirror Problems!  (Read 1260 times)
Offline Redev
« on: May 11, 2011, 06:14:59 pm »
Hi all,
I have a 05 GTi with folding door mirrors. Anyway I've noticed that if I use the adjuster to change the right hand mirror it's also moving the left!!
If I try to adjust the left it moves independently of the right!
Any ideas?
Black GTI, DSG, Cruise control, MFD2,  Leather, MFSW with paddles, Parrot kit, Xenons, CD Changer, Armrest, Come home lighting/puddle lights, mod list in glovebox waiting for some cash and sunny weather....
Offline Rampage
Re: Door Mirror Problems!
« Reply #1 on: May 11, 2011, 06:20:18 pm »
If you have Highline, it maybe that you need to adjust the settings in the Convienience menu buddy   :smiley:
Offline Redev
« Reply #2 on: May 11, 2011, 06:24:11 pm »
Nope, no highline! Worked fine up until today! So weird!
Offline Rampage
« Reply #3 on: May 11, 2011, 06:27:07 pm »
Bummer dude. Someone who actually knows what they are talking about will be along soon I'm sure buddy. Hope you get it sorted soon (and cheaply!)
GTIStevie
« Reply #4 on: May 11, 2011, 06:28:02 pm »
I think its a standard feature with golf mine does it too.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #5 on: May 11, 2011, 06:48:37 pm »
andy as said there is a option in the conveinience menu for adjusting both mirrors at the same time, can be changed via hihgline menu or vcds coding.  Odd that yours has just started doing it, luckily the left ones still indeoendant so you can adjust the right then re adjust the left!
Next time you get the opportunity get someone with VCDS to check the coding for you.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=j3ts8koko6dql8qrv1tula0mqe&/topic,19740.0.html
« Reply #6 on: May 11, 2011, 06:54:03 pm »
Its actually a good system if you use it properly, because it means that once 'set' the mirrors can be adjusted by adjusting one mirror only as the other one should adjust to suit!
Couldnt fit any more adjusting words in there  :signLOL:
Offline Redev
« Reply #7 on: May 11, 2011, 07:10:28 pm »
I wonder if I twiddled some form of strange setting by accident!
Offline Redev
« Reply #8 on: May 11, 2011, 07:16:37 pm »
Quote
Couldn't fit any more adjusting words in there  :signLOL:
I was "Adjust" thinking that! :signLOL:
  • -Receive: 291
« Reply #9 on: May 11, 2011, 07:47:37 pm »
Normal. VW "convenience" for you. If another person sits in the car and needs to say point the mirrors up, saves time to move them both up rather than having to fiddle with each one.
