Author Topic: Help......!!!!  (Read 1165 times)
Offline scott84
Help......!!!!
« on: May 11, 2011, 07:51:24 pm »
Hi,
Im halfway to removing my rear lower bumper but i just cant get it off!! Its only the lower 'plastic' section.
Ive removed all screws but it just wont 'unclip'!!!!
Is there a knack to getting it off?? Really dont want to chip the paintwork off the upper bumper so am worried about pulling it off!!!
Any replies appreciated......its getting dark!!    :happy2:
Offline big al
Re: Help......!!!!
« Reply #1 on: May 11, 2011, 07:55:44 pm »
Have you taken the screws from underneath as well? If so then you just Pull with all your strength from one side to the other. Good luck.
Offline scott84
Re: Help......!!!!
« Reply #2 on: May 11, 2011, 07:57:48 pm »
Yer i've taken them off the underside and from the wheel arches!! Yanking the only way then?!!!! :surprised:
Offline big al
Re: Help......!!!!
« Reply #3 on: May 11, 2011, 08:30:07 pm »
If you wanted to you could remove the top bumper as well and push the tabs down. I can't get to it right now but there is a YouTube video of how to remove it.
Offline big al
Re: Help......!!!!
« Reply #4 on: May 11, 2011, 08:57:47 pm »
Found it:
Offline big_pete
Re: Help......!!!!
« Reply #5 on: May 11, 2011, 09:55:03 pm »
Start off with using a flat blade screw driver and a quick spray of WD40 over the tabs and push them out and pull, easy peasey.
Offline scott84
Re: Help......!!!!
« Reply #6 on: May 11, 2011, 10:14:36 pm »
Cheers guys......got it off!! No damage to paintwork. The two large bolts had rusted so had to cut them off. So just need to replace those now!!
Offline aidogti
Re: Help......!!!!
« Reply #7 on: May 11, 2011, 11:05:15 pm »
hi, I did this a while back, got it off eventually, I colour coded mine and re-fitting was impossible unless you remove the top section of the bumper and assemble both parts off the car and then re-fit, removing the top section is quite easy.
HTH
Aidan
