Author Topic: Separating Vent and trim on centre section?  (Read 2073 times)
Offline johnhol78
« on: May 11, 2011, 08:55:37 pm »
I can see the vents actually come away from the top centre unit.
I have it out the car though want to remove the actually two vents to wrap the trim.
Anyone know how without breaking it?  :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Separating Vent and trim on centre section?
« Reply #1 on: May 11, 2011, 09:33:26 pm »
The y shaped hard plastic is a single piece that un-clips from the exterior plastic trim it looks like this in pieces.
Offline johnhol78
« Reply #2 on: May 11, 2011, 09:52:55 pm »
Saw it came away from the edges though it was stuck at the front.....do you pull down or back?
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #3 on: May 12, 2011, 10:43:00 am »
once the back is away just riggle the front forwards from memory
Offline johnhol78
« Reply #4 on: May 12, 2011, 11:03:47 am »
Thanks Rich...
Offline Jaywoo-GTI
  • -Given: 38
« Reply #5 on: May 12, 2011, 11:17:43 am »
Takes a little force to do it as above but it will separate and you will think you broke it when it comes apart,
Had to seaprate mine last night.
Offline johnhol78
« Reply #6 on: May 12, 2011, 11:24:34 am »
For all the wrappers on here.....do you lay the vinyl then cut around it? Leave a 2 mm overhang?
Or draw round it and try to lay the actual shape of the trim?
Also do you heat, peel, lay and stretch
Or
Peel, Lay, Heat and then stretch....Easier to bloody paint it... :grin:
Offline Kalpsn2000
  • -Receive: 56
« Reply #7 on: May 16, 2011, 11:36:30 am »
