Author Topic: RNS 510 A B AND C ?  (Read 29153 times)
Offline alexperkins
  • -Receive: 99
Re: RNS 510 A B AND C ?
« Reply #60 on: June 06, 2011, 09:39:13 pm »
The structure is fine
It looks like they are out of iTunes and therefore m4a format and not mp3. The RNS does not support anything but mp3 and wav
You'll have to convert them buddy
Offline DaveR77
    • UK-MKIVS.net
« Reply #61 on: June 06, 2011, 09:51:50 pm »
I had problems with SD cards when I had music in FLAC format on it, re-ripped to MP3 and all was fine. Is MPEG4 supported?
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #62 on: June 06, 2011, 09:58:15 pm »
Alex..........thanks for your help. How do you convert them then............or how do i get alot of music onto the hard drive of the RNS ?
« Reply #63 on: June 06, 2011, 09:58:47 pm »
Offline alexperkins
  • -Receive: 99
« Reply #64 on: June 06, 2011, 10:00:47 pm »
There's various free apps to do it. Google it bud
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #65 on: June 07, 2011, 01:11:24 pm »
How or when will i know whether i have battery drain or not. No noticable difference overnight , can any checks with a multi meter help me.....theres a canbus on the for sale section at moment cheaper than new from a stealer. :happy2:
Offline DaveR77
    • UK-MKIVS.net
« Reply #66 on: June 07, 2011, 01:28:16 pm »
here's the advice I got
http://www.mk5golfgti.co.uk/forum/index.php/topic,28589.msg367568.html#msg367568
Leave it off an hour. If it shows the VW screen on boot up then it should be fine  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #67 on: June 07, 2011, 01:50:16 pm »
Its also important to note that the VW screen will not always show on boot up
The only time you will see is if you open the door and start the engine/ignition on as quick as you can as it will boot as soon as the door is opened to speed up loading time
Battery goes flat in a day to two days if the issue is there
Most cars March 07 onwards do not suffer this problem however.
Offline DaveR77
    • UK-MKIVS.net
« Reply #68 on: June 07, 2011, 02:02:49 pm »
Mine was Jan 07 (K) and was fine
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #69 on: June 07, 2011, 02:06:57 pm »
Yes i have a K and May 2007. Does your set turn on and play even with the ignition off?
Offline alexperkins
  • -Receive: 99
« Reply #70 on: June 07, 2011, 02:08:54 pm »
You should be fine then buddy
Yes I can use it with the ignition turned off if I wish
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #71 on: June 07, 2011, 02:13:07 pm »
converting mp4 to mp3......what is  recommended free software..........have tried two and they are poor/sh!t
Offline alexperkins
  • -Receive: 99
« Reply #72 on: June 07, 2011, 02:17:00 pm »
its M4A to MP3
MP4 is a video file (even though M4A is called MPEG-4, M4A is the 'audio' version)
You can in fact do it in iTunes if you change the import settings in Edit > Preferences to MP3, then right click the songs you want to convert, choose Create MP3 version
Would recommend you set the quality in the import settings to at least 128kbps (personally I go for 192 or 256 depending on how many songs/how much space you have available)
To seperate them out, right click the columns at the top and choose File Type, and then youll have a new column that shows if its an MP3 or not
Does that help  :happy2:
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #73 on: June 07, 2011, 03:40:16 pm »
Done it , got stuff on my hard drive :laugh:...............................................ALEX THANKS :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #74 on: June 07, 2011, 03:42:14 pm »
No worries dude
be sure to hit the 'Thank You' button to the right  :drinking:
