Author Topic: Problem pulling away(DSG)  (Read 2832 times)
Offline M7AXB
« on: March 10, 2009, 11:29:23 pm »
Hi guys,
I've been having a spot of bother, every now and again when pulling away from a junction or roundabout I push the accelerator and nothing happens for a couple of secs then the car pulls away! Anyone know what is causing the problem..I'm guessing the DSG gearbox is to fault! My car is an 05 with 50k if that helps.
Thanks :smiley:
Max
Offline GTIjames
Re: Problem pulling away(DSG)
« Reply #1 on: March 11, 2009, 09:45:51 am »
have you been for your DSG service yet? i think after around 45k miles on the clock you are meant to have one.
speak with your local vw garage
« Reply #2 on: March 11, 2009, 11:19:40 am »
4 years or 40k miles for the DSG service. :happy2:
Offline no golf clubs at all
« Reply #3 on: March 12, 2009, 12:13:32 pm »
Any issues putting it in earlier for this? I am at 35000 and 6 months to the 4th year anniversary...
« Reply #4 on: March 12, 2009, 12:42:35 pm »
No, I did mine at just over 10k miles :smiley:
« Reply #5 on: March 12, 2009, 11:08:43 pm »
Beginning to wish I had done it whilst under warranty! Just in case...... Why so early Hurdy? 10k!!!! What were you worried about? Or....?
Offline animal
  • .:R32
« Reply #6 on: March 13, 2009, 12:03:06 pm »
Presumably a DSG service includes an oil change? Its good practice to change gear box oil early on a new car, normally after a couple of thousand miles. Doing it at 10k certainly wouldn't be a bad thing to help wash out the swarf from running the 'box in.
« Reply #7 on: March 13, 2009, 12:07:27 pm »
The DSG box does improve after a service but Hurdy had his done as a fix to try and stop the bit of slip he was getting, as he has abused his down the strip often  :grin: and his car has a high level of torque.
Offline animal
  • .:R32
« Reply #8 on: March 13, 2009, 12:23:50 pm »
Ah I see - punishing a gearbox down a strip with less than 10k on it? At least it's being used properly!  :happy2:
The older 6spd DSG 'box on the GTi is wet clutch - correct?
« Reply #9 on: March 13, 2009, 01:35:51 pm »
Yes you are correct.  :smiley:
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
« Reply #10 on: March 13, 2009, 06:25:11 pm »
Have a look here, could be the same issue as mine?
http://www.mk5golfgti.co.uk/forum/index.php?topic=2830.0
Cheers,
Wayne
Offline M7AXB
« Reply #11 on: March 14, 2009, 06:12:10 pm »
She booked in for a service on wed, hopefully that will solve the issue, thanks for the help guys!
