Author Topic: door adjustment  (Read 2058 times)
Offline jamma
door adjustment
« on: May 14, 2011, 12:18:32 pm »
I noticed my drivers door is not flush, is there a way of adjusting it? If so they can do it next time I nip to VW on warranty
cheers
rileyboy
Re: door adjustment
« Reply #1 on: May 14, 2011, 08:05:35 pm »
my doors have the same thing vw just made it worse 5 times it has been back and i am still not happy
Offline adamf
Re: door adjustment
« Reply #2 on: May 15, 2011, 10:40:25 am »
Yes there is adjustment on the hinges. Have a word when you go on and try should sort it out. Should only take 5 mins  :drinking:
Offline jamma
Re: door adjustment
« Reply #3 on: May 16, 2011, 12:16:12 pm »
thanks
Offline heavyd
  • -Receive: 29
Re: door adjustment
« Reply #4 on: May 17, 2011, 12:24:47 am »
is it the front or rear of the door?
rear half of the door is adjusted by the door striker, the thing that the lock fastens on to, easily adjusted by slackening the  bolts off and moving it out a litlle :happy2:
 if its the door to fender flush ,  plastic wedge and prise the fender in or out - wouldnt do this if you havent done it before as you can make a mess of the door
Offline 182_blue
  • -Receive: 54
Re: door adjustment
« Reply #5 on: May 17, 2011, 06:22:42 am »
As above, it all can be adjusted, they did my edition 30, it involved moving the wing out a bit too !
Offline jamma
Re: door adjustment
« Reply #6 on: May 20, 2011, 02:19:04 pm »
Just been to VW, they adjusted my door, all fixed so happy  :happy2:
