Author Topic: Help!!!!!! Dsg problem  (Read 24512 times)
Offline Gti_Mad
« on: May 15, 2011, 01:35:22 am »
Help can't get gears the gear indicator lights on dash n selector are flashin stuck across sum1's drive
Help needed urgently
  • -Receive: 801
Re: Help!!!!!! Dsg problem
« Reply #1 on: May 15, 2011, 01:36:39 am »
sh*t.... sounds like its gone t*ts up!  :scared:
Offline Gti_Mad
« Reply #2 on: May 15, 2011, 01:41:03 am »
I hope not mechatronics is less than 2months old !!!!!!
  • -Receive: 801
« Reply #3 on: May 15, 2011, 02:04:19 am »
IIRC flashing dsg lever lights points to i being Mechatronics... at least it will be under warranty!
Offline Poppa Dom
« Reply #4 on: May 15, 2011, 07:55:30 am »
Does sound like mechatronics  :sad1:
Offline alexperkins
  • -Receive: 98
« Reply #5 on: May 15, 2011, 08:48:42 am »
VCDS scan asap mate!
Offline Gti_Mad
« Reply #6 on: May 15, 2011, 09:33:55 am »
I'm stuck no where near home gotta try get it home then get some1 local with VCDS 2 hopefully come mine and scan it 4 me  :sad1: :sad1: :sad1:
Offline alexperkins
  • -Receive: 98
« Reply #7 on: May 15, 2011, 09:36:41 am »
Where are you now?
  • -Receive: 801
« Reply #8 on: May 15, 2011, 09:36:59 am »
Where are you? Drop me a text!
Offline Gti_Mad
« Reply #9 on: May 15, 2011, 09:43:25 am »
I'm in whitton near twickenham
Offline Gti_Mad
« Reply #10 on: May 15, 2011, 10:21:05 am »
My mate from twickenham Vw has stole a comPuter from work and has scanned the car the codes are
28775- lost communication with gear shift module-static
02413- selector lever park position lock switch-f319 implausible signal-static
  • -Receive: 801
« Reply #11 on: May 15, 2011, 10:23:11 am »
Taken from ROSS-TECH WIKI!!
http://wiki.ross-tech.com/wiki/index.php/28775/U0103/049411
28775/U0103/049411 - No Communication with Gear Selector Module
Possible Causes
Communication Failure with Gear Selector Module
Communication Failure between CAN-Gateway and Transmission Control Module
Selector Lever (E313) faulty
Tiptronic Buttons (F189) in Selector Lever (E313) faulty
Shift Selector Locking Solenoid (N110) faulty
Offline alexperkins
  • -Receive: 98
« Reply #12 on: May 15, 2011, 10:30:19 am »
It does point to a pretty serious problem
A 'Basic Settings' might clear it
Offline Gti_Mad
« Reply #13 on: May 15, 2011, 10:54:48 am »
He's tried that Alex with no joy  :sad1: :sad1: :sad1:
  • -Receive: 801
« Reply #14 on: May 15, 2011, 10:58:44 am »
Again from ross tech
http://wiki.ross-tech.com/wiki/index.php/02413
02413 - Switch for Selector Lever Position P Lock (F319)
02413 - Switch for Selector Lever Position P Lock (F319): Implausible Signal
Possible Causes
Control Module for Steering Column Electronics (J527) faulty
When stored in Combination with 00003 - Control Module: Defective
Possible Solutions
Check Control Module for Steering Column Electronics (J527)
i dont think that is a mechatronics problem.
