Author Topic: Help problem  (Read 955 times)
Offline gti265
Help problem
« on: May 15, 2011, 05:57:11 pm »
Hello all my rear high leval brake light isnt working and i cant find a fuse for it
Any help would be great
Tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline Little_Dave
Re: Help problem
« Reply #1 on: May 15, 2011, 06:06:09 pm »
Hi Tom,
I may be wrong but i think if its stopped working its usually because water has got into the brake unit and knackered the LED's. Mine stopped working a while back and its a very expensive fix if you take it to a dealer, believe they need to cut off the spoiler and bond a new one back on and re spray the rear about £400 iirc  :scared:
Some people i've seen in posts on here have done it by cutting out the brake unit themselves, using a drill and trim removal tools, which is an option if your out of warranty.
Dave
Saint Steve
Re: Help problem
« Reply #2 on: May 15, 2011, 06:19:11 pm »
Hi Tom,
Dave
This is the way to do it.The new light assembly just clips in, rather then the 2 fastening screws the old light assembly used.
Don't have the spoiler removed ..
Offline gti265
Re: Help problem
« Reply #3 on: May 15, 2011, 06:29:36 pm »
I have just found a thread on another gti forum with step by step instructions on how to do it, so hopfuly that shall fix it,
Could it be anything else as i have never noticed water in it and my rear wiper is not conected atal so no washer fluid getting in from the sprayer
Tom
Offline Little_Dave
Re: Help problem
« Reply #4 on: May 15, 2011, 06:36:23 pm »
Its usually from the washer jet but in your case its probably just run off the roof and down behind the spoiler, i imagine it wouldnt take much to bugger the circuit board the LEDs are on so doubt you'd see the brake full of water. I was going to give it a go at replacing mine as i was worried about it failing the MOT but it passed so have left it for now.
Dave
