Author Topic: Squeak on Start Up  (Read 3822 times)
Offline Rob GTI
Squeak on Start Up
« on: May 16, 2011, 05:58:16 pm »
Only noticed this today, while the engine is turning over / firing there is a what sounds like a belt squeaking for a second. It dissapears once the engine is running.
As I said not noticed this before and wonder if anyone else's car does it, normal or not, common fault?
I remember I has a Renault years ago that did this and it turned out the fan belt was too tight snapped wrapping iteslf around the timing belt pulley causing the timing belt to slip, bend valves and snap the cam, not good so just cautious when I here similar sounds.
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline flyboy1976
Re: Squeak on Start Up
« Reply #1 on: May 16, 2011, 07:11:56 pm »
if it happens for about 5-10 minutes then goes away as the car reaches temperature that will most def be the water pump!
Saint Steve
« Reply #2 on: May 16, 2011, 07:20:24 pm »
Cam belt tensioner is the problem
Offline TrickGTI
« Reply #3 on: May 16, 2011, 07:24:39 pm »
^^^ I would normally agree but the starter motor does this! Would need to hear the noise. And as it goes away straight away then it points to that at the moment.
2006 Tornado red GTI
Offline gazon69
« Reply #4 on: May 17, 2011, 02:41:50 pm »
mine does this. been told it's the starter motor.
Offline mo
« Reply #5 on: May 17, 2011, 03:23:57 pm »
Mine was doing this until i had the cambelt and water pump changed last week.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline Rob GTI
« Reply #6 on: May 17, 2011, 09:03:46 pm »
Thanks for the replies guys, of course I'll be getting it checked out professionally the thread was about trying to guage a possible source. Btw its gone today, which means it gonna be hard to get a diagnosis if the issue ain't there when i take it in.  :jumping:
Offline patrickcullen87
« Reply #7 on: May 17, 2011, 09:12:24 pm »
mines does this aswel, lets out a wee squeel when i start it up but have been told its the starter motor
Admin Notice Sig Removed - Signature images should be no bigger than 450 pixels wide x 150 pixels high
