October 06, 2024, 10:26:59 pm
All Things Mk5
Sat Nav and Car Audio
Replacing RCD300
Topic: Replacing RCD300 (Read 1538 times)
jkerry2782
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Replacing RCD300
May 16, 2011, 08:34:18 pm »
Hi have just brought a golf gti 2005 with an RCD300 and ipod in the arm rest, if i upgrade to a RCD310 exactly what parts do i need to complete the job and if possible can i have links to the parts please.
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: Replacing RCD300
Reply #1 on:
May 16, 2011, 08:38:38 pm »
Hi
If you upgrade to the RCD310 or newer type vw radios you will need a new CAN Gateway
do you have Vag-com?
if not what is your location?
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
jkerry2782
-Given: 0
-Receive: 0
Reply #2 on:
May 16, 2011, 08:40:54 pm »
hi i am near norwich and have no idea whihc can gateway i need and are they just plug and go, it been while since i did any stereo changing.
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #3 on:
May 16, 2011, 08:45:16 pm »
Hi
I'm in Great Yarmouth and have Vag-com and do retrofits. I changed someones gateway only yesterday. I also am able to get hold of some for less than what the dealer charges.
Ed
jkerry2782
-Given: 0
-Receive: 0
Reply #4 on:
May 16, 2011, 08:47:51 pm »
Hi so how much does it cost for you to change the gateway so the car will work with rcd 310 and will the ipod system work with as well.
janus909GTI
Always Involved
-Given: 0
-Receive: 1
Reply #5 on:
May 18, 2011, 05:20:03 pm »
Ed, what is Vag Com???
I'm looking to get the RNS510, also have a 2005 gti, what do i need to do?
Plus, do you have any of these in stock?
hugh jass
Reply #6 on:
May 18, 2011, 05:38:44 pm »
http://wiki.ross-tech.com/wiki/index.php/Main_Page
vag com is now called VCDS
All Things Mk5
Replacing RCD300
