looking at my dyno graph you can see the power peaks at 5000rpm and tails off gradually to 200Hp at 6500rpm.
This isnt a big drop in power by any means and very likely wouldnt even notice the drop off in real life. However the difference in torque between 5000rpm and 6500rpm is around 45lbft and surely 45lbft you would notice.
Now what im thinking is would it be better for me to change gear at 5000rpm just after i reach peak power (210Hp/180lbft), the revs will drop to say 4250rpm which is around 205hp/250lbft
so changing gear earlier im essentially staying in the power peak power AND peak torque for longer as its not dropping off at all.
![](https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fxx202%2Fsimonskerton%2Fimg004.jpg&hash=8a4d320831108b236bacce2c8a74590fb3a2b0d9)
Also id be ragging the engine much less which is of course a big plus.
Thoughts guys as ill be taking it on the 1/4 very soon????
