Author Topic: remote wire  (Read 5100 times)
Offline barratt
remote wire
« on: May 19, 2011, 06:49:01 pm »
I'm having an issue getting my head around wiring up the remote on wire for my sub  :confused:
I'm using an aftermarket headunit and i have the connects 2 CTSVW002 can bus wiring harness. On my previous audio installs the wiring harness had a spare blue wire which i hooked up my sub remote on wire to. But looking at this now the only spares are the pink speed/pulse, green park brake, purple reverse which are rather useless to me :(
I tried searching the forum but didn't find anything on it. All help appreciated!
MK5 1.9 TDI BXE - AET Turbo's Remap - 140hp/325nm - GTTDI Leathers - GTI Headlights - R32 Rear lights - HEX+CAN VCDS
Offline alexperkins
  • -Receive: 99
Re: remote wire
« Reply #1 on: May 19, 2011, 06:56:11 pm »
I tagged mine onto the rear 12v socket. Works perfectly  :happy2: Though granted only when the ignition is on.
Offline barratt
Re: remote wire
« Reply #2 on: May 19, 2011, 07:12:14 pm »
I didn't think of that. I suppose it's a last resort. But tbh as you said there is a bit of a downside there! Another thing would be is if you don't have your HU on your going to have the sub on for no reason :(
Not sure if this would work but. I noticed there is a "power antenna" blue wire that goes from the quadlock to the iso end. If I tap into that I'm guessing it would perform the same function?
Hopefully some ones done it a more proper way and will chime in  :happy2:
Offline alexperkins
  • -Receive: 99
Re: remote wire
« Reply #3 on: May 19, 2011, 07:18:47 pm »
Tbf I always have my HU on so that makes no difference to me  :P
That could well work. That will send a 12V feed whenever the radio is generally on - try it with a multimeter and see if it has +12V when you put the HU on
Offline barratt
Re: remote wire
« Reply #4 on: May 21, 2011, 06:31:11 pm »
I was gonna try it today but I only just managed to get my stereo in before I had to go somewhere. Even though I have the connects2 can bus compatible harness, my stereo would not power up. I had to tap a wire that went to the OBD port to get ignition / switched. Considering it should have worked without this I'm rather confused! Unless the stereo needs to be canbus compatible, who knows.
Gonna take a peek around tomorrow for the remote on wire, see what i can figure.
Offline PaulGTI
Re: remote wire
« Reply #5 on: May 22, 2011, 01:34:16 am »
The Blue power antenna wire does the same job as the remote wire for a sub so you can use that mate and it also powers the aftermarket amplified radio antenna adapter you'll need
