Author Topic: Black Pirelli  (Read 9239 times)
Offline k04golf
Re: Black Pirelli
« Reply #15 on: May 27, 2011, 10:42:07 pm »
Welcome Mate Lovely Car you have there!
MK5 GTI, Revo Stage 2 +, Neuspeed Intake, Full 3" Exhaust + Decat, RS4 Press Valve, BSH Competition Catch Can, Autotech HPFP, R32 Brakes, Full KW Coilovers, Leon Cupra R Walk Kit, Eibach Front ARB, R32 Tail Lights...... Full K04 Kit Waiting To Be Fitted!
Offline pipston
Re: Black Pirelli
« Reply #16 on: May 30, 2011, 11:11:20 am »
Welcome along!
Did anyone else notice in the pics the car has high line but no mfsw....how are you supposed to navigate the menu???
I would guess it's a retrofit as the car also has an rns510?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Black Pirelli
« Reply #17 on: May 30, 2011, 12:27:06 pm »
Welcome along!
The right hand stalk buttons navigate the menu. Some R32's also havet no MFSW buttons, although they came with highline as standard. Doesn't necessarily mean there's been a retrofit.
Offline Pirelli Paul
  • -Given: 64
Re: Black Pirelli
« Reply #18 on: May 31, 2011, 12:44:30 pm »
Hi Piston
Not aware there was a retro fit as came from the dealer as far as I know, but I would of liked a MFSW but dificult to change as would need a Pirelli one with yellow stitching so will make do with the right hand stalk for bringing up the menus.
Has anybody got any feedback on the Pivot XV muliti guage, Japanese but I think I can get hold of one here in Hong Kong, they can be swithed between boost oil, oild and water temperature I think, just plug in the and read from the ECU, wondered if anyone has used one or seen one and can advise how they work.
Check them out on You Tube they look nice and a perfect match to the clock lighting, was thinking about one in a OSIR vent pod.
Offline apollo13
  • -Receive: 47
Re: Black Pirelli
« Reply #19 on: May 31, 2011, 02:44:43 pm »
Welcome along, lovely looking Pirelli  :happy2:
Welcome along!
Thats not true, R32's came with midline clusters too mate  :happy2:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Black Pirelli
« Reply #20 on: May 31, 2011, 02:59:56 pm »
Well I'll be... I didn't know that!
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
Re: Black Pirelli
« Reply #21 on: June 03, 2011, 11:04:42 pm »
Hi and Welcome along..... :driver:
Cheers,
Wayne
  • -Given: 64
Re: Black Pirelli
« Reply #22 on: December 18, 2011, 04:53:21 am »
I knew I wouldn't last long before I started upgrading things.
Last 2 trips back to the UK I had works done on the brakes and suspension and I looking forward to the tuning mods on another trip back hopefully soon.
List of changes and pending changes since buying the car below.
Others (Completed)
1.   Pivot XV Boost/Water/Oil Gauge
2.   Osir mono vent pod
3.   VW Safety Kit
4.   Autoglym Lifeshine
5.   Semi Rigid Loadliner
6.   Osram Nightbreaker main beam bulbs
7.   Cruise Control
8.   Daytime Running Lights Via Front Fog Lights
Brakes (Completed)
1.   Tarrox Sport Japan Drilled & Slotted Front & Rear Brake Discs
2.   EBC Yellow Stuff Front Brake Pads
3.   EBC Yellow Stuff Rear Brake Pads
4.   ATE Super Blue Brake Fluid Service
5.   Neuspeed Stainless Steel Brake Lines
Handling (Completed)
1.   Neuspeed Torque Arm Insert
2.   Neuspeed Short Shift Kit
3.   Bilstien PSS10 kit
4.   Neuspeed front anti roll bar 25mm
5.   Neuspeed rear anti roll bar 25mm
6.   Neuspeed rear sway bar links
7.   Whtieline anti lift kit
8.   Front wishbone front power flex bush
9.   Whiteline bump - steer adjust kit
10.   Neuspeed triangulated upper rear strut brace
11.   Beissbarth 4 wheel alignment
Performance (Under review and will arrange for early 2012)
1.   Milltek None Resonated Cat-Back Exhaust System
2.   Milltek Large Bore Downpipe and Hi-Flow Sports Cat
3.   Forge Blow Off Valve kit
4.   Forge Twintercooler
5.   ITG Maxogen Induction Kit
6.   Forge Silicone Coolant Hose Kit
7.   Forge Silicone Throttle body hose
8.   Forge DV to Intake return Hose
9.   Revo serial port switch
10.   Revo stage 2
 The diference to the handling is outstanding and I am looking forward to the performance mods which should take it to around 310 bhp.
I can't wait
Cheers Paul
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
Re: Black Pirelli
« Reply #23 on: December 18, 2011, 01:43:51 pm »
Some great mods your working on there. Enjoy it at 310bhp it'll be awesome  :evilgrin:
Offline RENNTAG
  • Premium Performance Parts
Re: Black Pirelli
« Reply #24 on: December 19, 2011, 02:37:55 pm »
Welcome!
Very nice car you have there.Will be awsome after that list of mods  :happy2:
Offline Dw1
Re: Black Pirelli
« Reply #25 on: December 21, 2011, 01:22:57 pm »
That looks stunning, it's going to be a beast with all those mods.
  • -Given: 64
Re: Black Pirelli
« Reply #26 on: December 22, 2011, 01:34:19 pm »
Thought I would add some updated pictures of the recent mods
New Brakes discs, pads and brake lines and fluid
New boost gauge (Lights up blue and has boost, water & oil temp which I got in Hong Kong but its made in Japan)
Car after brake upgrade and prior to handling upgrade and lowering
Goodies to go on
WALK kit and anti sway on the front (Bump steer also fitted and poly bushes)
Front Bilstiens going on
Rear Bilsteins going on (Also anti sway bar and drop links were fitted) and finished off with a Biessbarth 4 wheel alignment
Also I fitted the Neospeed rear triangulated upper rear strut brace in the back (No pictures unfortunately)
All works carried out by Jon & Ben at Vagtech Milton Keynes (Top guys and thanks to them and also Victoria)
Looking forward to the next upgrades on the Engine when back in the UK so I can put the 300+ BHP through the chassis to really check out the handling.
Cheers Paul  :driver:
Offline baldwined30
Re: Black Pirelli
« Reply #27 on: December 22, 2011, 01:42:05 pm »
Really nice mate! SHame about the gearbox!!!! :wink:
Ed30
  • -Given: 64
Re: Black Pirelli
« Reply #28 on: December 22, 2011, 02:00:53 pm »
 :laugh: Yeah I did think about a DSG but went with a manual for a change
Offline maxload
  • -Given: 41
  • -Receive: 29
Re: Black Pirelli
« Reply #29 on: December 24, 2011, 07:45:45 am »
I prefer the manual box. Gives you more of a feel for the car as you drive. The clutch and gears are superb , really light and easy. Poke your Automatic dsg
