Author Topic: Software update problems  (Read 8393 times)
Offline Lyons
  • -Given: 18
« on: May 21, 2011, 01:45:37 pm »
Basically my Columbus started as a 2684, then was upgraded to 2724 before I got it.
I retro fitted a MFSW and am in the process of installing a fix to make it work with maxidot and MFSW.
A chap on briskoda kindly sent the CDR disc (which originated from vRSstu I believe). I put it in, and after having to press setup, eject and mic it eventually got underway.
I left it going for a while and came out to check process there and the disc was ejected and it says SWL error, error description. Then in small writing it says about putting it on a different media etc.
I put the disc in again and it was at 43%, but it ejected straight away and the same thing displayed.
Now I'm too afraid to even breathe incase I brick it etc. What's the craic, is this an easy solution?
The radio just displays; "software download- source activated, searching for SWL image" all the time, even when driving and when the car is off and key out.
An I going to have to disconnect the unit tonight?!
« Last Edit: May 21, 2011, 02:31:06 pm by Lyons »
Offline alexperkins
  • -Receive: 99
Re: Software update problems
« Reply #1 on: May 21, 2011, 01:55:42 pm »
Sounds like the disc is dodgy. You may need to use the SWL recovery disc and reflash a working software
Is it a B or a C?
Offline Lyons
  • -Given: 18
« Reply #2 on: May 21, 2011, 01:56:58 pm »
C. The disc itself has been used before.
Can I turn it off ant work at it another time!?
Offline Lyons
  • -Given: 18
« Reply #3 on: May 21, 2011, 04:18:10 pm »
If I put the disc back in it allows me to go through the whole procedure again and starts at 26%. But then when I cone back to the car it says the same error.
Would it be worth trying the file on a different disk? Could it be as simple as that?
I assume the recovery file I need to try if all else fails is the 1 at the top of this link?
http://vwnavi.com/showthread.php/13672-Unofficial-272x-software-and-SWL-recovery-CD
Offline alexperkins
  • -Receive: 99
« Reply #4 on: May 21, 2011, 06:49:52 pm »
Id try a different software all together - if its a C id personally take it to 3970. I run that on mine and it works perfectly
Offline Lyons
  • -Given: 18
« Reply #5 on: May 21, 2011, 07:39:23 pm »
I need that particular one sadly as it has the MFSW tweak.
Offline alexperkins
  • -Receive: 99
« Reply #6 on: May 21, 2011, 07:54:07 pm »
Ah yes that old chestnut I remember reading something about that
What tweak does it have for the MFSW then
Offline Lyons
  • -Given: 18
« Reply #7 on: May 21, 2011, 08:16:09 pm »
LOL, I literally have no idea! I'm in over my head!
Just tried the 2760 but anytime I put it in, it just kept coming back out.
Offline alexperkins
  • -Receive: 99
« Reply #8 on: May 21, 2011, 08:17:56 pm »
U tried the modded software on vwnavi.com?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: May 21, 2011, 08:27:59 pm »
 Don't know that it would of originated from me - Who sent it to you?
Stu...
Offline Lyons
  • -Given: 18
« Reply #10 on: May 21, 2011, 08:38:46 pm »
Lol, I thought it had! Mikeholroyd.
Well, the file anyway. Perhaps he just meant it was passed from member to member. I just meant at least it's a genuine source, so I know the file isn't the problem.
Anyway, I download both the fix itself and then the recovery, but neither are being taken by the Columbus. It just shows the Skoda start up screen with the red strips top and bottom stating the system is not able to start up and please insert SWL cd.  I've tried pushing eject, mic and set up but nothing happens. Just keeps taking the disk in and firing it out!
For the recovery, is it literally just 1 nrg file?
Offline alexperkins
  • -Receive: 99
« Reply #11 on: May 21, 2011, 08:41:44 pm »
The NRG is a disk image and needs to be burnt to the disc properly btw
Offline Lyons
  • -Given: 18
« Reply #12 on: May 21, 2011, 08:42:38 pm »
Ah right. How? Not just a case of copying to disc!?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: May 21, 2011, 09:00:10 pm »
Are you using decent disks?  Verbatim are the best IMHO.
Stu...
Offline Lyons
  • -Given: 18
« Reply #14 on: May 21, 2011, 09:01:47 pm »
I found some Maxell there, so just using them!
How do I burn the nrg file properly?
I apologise for my ignorance, I know this is probably basic stuff but it's beyond me!
« Last Edit: May 21, 2011, 09:03:36 pm by Lyons »
