Author Topic: OEM Polo Aerial fitted with pics  (Read 13210 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: OEM Polo Aerial fitted with pics
« Reply #30 on: May 26, 2011, 01:15:10 pm »
Noooo! Bummer, sorry dude! How is this the case? Could your headunit require more signal than the one I had in my R32?(had a basic oem single unit with 6 disc in the armrest... Or did the older r32's have the secondary amplifier that is spoken about...?
Diesel Daily Hack.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #31 on: May 26, 2011, 01:51:56 pm »
Hey Dom, Not sure what could be different it could be that the RNS which now does the diversity for the antenna isnt as good as the seperate box or doesnt boost the signal.  It doesnt matter it was a potential cheap fix will fit a shark fin and do as recomended by Apollo13 and put the full aerial under the roof in the head lining and see how that goes, as a longer term solution I will have to look at the second rear window aerial once I have chance to remove the trim.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #32 on: May 26, 2011, 02:38:46 pm »
LOW,
the older Mk.Vs without roof antenna had two window arials when
they came with RCD300/500, RNS MFD or RNS510 from factory.
If fitted with RCD210 or RNS300 they came with just one window
antenna.
The later Mk.Vs came with roof antenna + one window antenna
except RCD210 and RNS300 which had the roof arial only.
"You get what you pay for."
