Author Topic: Need Help with Cruise Control Fitting Please  (Read 13305 times)
Offline plex
  • Awesome Rabbit !
« on: May 22, 2011, 06:21:01 pm »
Hello,
I'm French, sorry for my bad English.
I'm on board since few months and really enjoy this board.
Actually, I'm searching for informations about Cruise Control Fitting but do not find solution.
Few days ago, I put the new stalk on the car but doesn't work.
Some Details :
Car : Golf MKV Gti Edition 30
Year : 2008-03
Transmission : Manual.
Equipements : RNS510, Steering Wheel with Multifonction, no phone or bluetooh.
Cruise Stalk : 1k0 953 513G
Modul : 1K0 953 549 BP
Operations :
Work out & having the black & with wire on 13 pin, puting the new stalk and work up all the stuff.
Starting to code on VCDS but have some problems here.
In Steering Wheel (16) ; Codding (7) ; I do not have long codding.
Here are VCDS screens :
Codding :
I try to put 0003041 or 0003042 but the green light on board doesn't appear :'(
I don't have rear wiper anymore, so 0003041 seems to be right but VCDS gives my many errors on wipers and bad code for module :(
Now, many threads are talking about Engine Codding
Code: [Select]
Factory fresh ECU's often come with cruise control de-activated. If this is the case, there will not be a letter "G" in the Component field of VAG-COM when connected to the Engine.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
I do not have login 11 in Engine.
Maybe there is another number to change ?
Can someone help me please ?
Bests regards :)
Marc
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Need Help with Cruise Control Fitting Please
« Reply #1 on: May 22, 2011, 06:36:58 pm »
Bonjour
the steering controller coding 0002022 should work
The coding in the engine needs to be done
Coding > Long Coding > tick the box Cruise control
Cluster and Key coding
Location Great Yarmouth
Offline plex
  • Awesome Rabbit !
« Reply #2 on: May 22, 2011, 06:57:25 pm »
Bonjour
Bonjour Eddie-NL and thanks for your answer :)
The steering controller coding 0002022 works yes but cruise control doesn't work. I do not have the green light.
I try to run the car few meters but it doesn't work too.
About engine coding, I do not have long codding here or Cruise Control Box.
Some other threads about ED30 cruise fitting says that Engine coding is not necessary.
I'll made some screens as soon as possible because I work out everything to see if something wrong but no.
Anyone having others informations please?
I think I'll be totaly crazy  :stupid: :star:
Bests thanks  :notworthy:
« Last Edit: May 22, 2011, 07:03:06 pm by plex »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: May 22, 2011, 07:00:33 pm »
If your car is an Edition 30 with a 2.0T FSi Engine
you need normal coding and not Coding II
Use normal coding and use Long Coding Helper
Offline plex
  • Awesome Rabbit !
« Reply #4 on: May 22, 2011, 07:05:14 pm »
Yes off course, Normal Codding.
I try many coding but not working :(
Maybe I have to enter 0003041 with some other values (workshop ...) ???
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: May 22, 2011, 07:09:11 pm »
0403000318070060 coding not for cruise
0403000318070160 coding for cruise
3rd digit working backwards needs to be a 1
Offline plex
  • Awesome Rabbit !
« Reply #6 on: May 22, 2011, 07:12:46 pm »
Okay Eddie, I ll try to find to do this.
Thanks so much  :notworthy:
Okay, well done, everything worked up,
Swith on the car, runing VCDS
Codding is now accepted.  :laugh:
Going to Steering Wheel now :
No errors in Fault Codes. Exit VCDS.
Switch off the car.
No green light ;'(
Have I to run few meters ?
« Last Edit: May 22, 2011, 08:09:01 pm by plex »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: May 22, 2011, 08:07:39 pm »
the login 11463 is for cars that don't use long coding, normally diesels or NA petrol.  It's not applicable to your TFSi.
Stu...
Offline plex
  • Awesome Rabbit !
« Reply #8 on: May 22, 2011, 08:17:58 pm »
Mmm does Workshop, Importer Number or Equipments numbert have to be changed to ?
I have multi fonction steering wheel, no voice or bluetooh, manual transmission, and big board computer.
Code seem to be 0003042 ? but not work and with errors.
0002022, no errors but do not work too
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: May 22, 2011, 08:20:13 pm »
Workshop number etc can be left at the original details.
@ Eddie - Scott was trying to sort an ED30 yesterday an IIRC the part number for that steering controller ends in BP like the one above.
Plex please post up a full autoscan of your car.  :happy2:
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: May 22, 2011, 08:21:57 pm »
Ignore that I just checked and it wasn't BP in which case I think the Autoscan of Hedges old car I looked at yesterday must have been BP with factory CC.
Stu...
Offline plex
  • Awesome Rabbit !
« Reply #11 on: May 22, 2011, 08:24:59 pm »
Ok for full scan but there are some errors because of the supply cutting.
Today, not any errors.
Please find full scan :
VCDS Version: Beta 11.2.0 (x64)
Data version: 20110305
Sunday,22,May,2011,21:25:50:03533
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W277075   Mileage: 59240km/36810miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0H13NR8GO
   Coding: 0403000318070160
   Shop #: WSC 01279 785 00200
   VCID: 3753E7593D8D
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB13496975
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DFF05310F51
1 Fault Found:
01273 - Fresh Air Blower (V2)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000008109572
   Coding: E78F8F2700041520471400001400000000097F075C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71C719411369
   Subsystem 1 - Part No: 1K1 955 119 E
   Component: Wischer 200208 021  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AF
   Component: RLS     070308 046  0204
   Coding: 00471077
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1UTCJB
   Coding: 0013111
   Shop #: WSC 01269 785 00200
   VCID: 3D5FF5711FB1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           051 0100
   Coding: 0003042 >> no errors with 0002022
   Shop #: WSC 01357 011 00200
   VCID: 8127C981A3C9
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 874     HW: 1K6 920 874
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H13NR8GO
   Coding: 0007103
   Shop #: WSC 00200 216 72168
   VCID: F0C19C459863
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 290208F2000719
   Coding: E9811F064002020000
   VCID: 3041DC45D8E3
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 2216
   VCID: F0C19C459863
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 A    HW: 1T0 035 680 A
   Component: RNS-MID       H04 1020
   Revision: AB001001    Serial number: VWZ6Z7H6064039
   Coding: 000004000400001200
   Shop #: WSC 01316 785 00200
   ASAM Dataset: ------------------------- ------
   VCID: 2C79C835F4CB
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1207
   Coding: 0000054
   VCID: 3957E1610B99
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 354FED512781
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002085103087F2D0284057008CAC6F0BC00
   VCID: 832BC389B9D5
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000310
   VCID: 3A55FE6D0E9F
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4C99055EC7B
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2C79C835F4CB
End   ---------------------------------------------------------------------
« Last Edit: May 22, 2011, 08:26:40 pm by plex »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: May 22, 2011, 08:30:21 pm »
ECU - Engine 01 looks ok to me.
Try 0002021 on the Steering Wheel 16.
Stu...
Offline plex
  • Awesome Rabbit !
« Reply #13 on: May 22, 2011, 08:34:52 pm »
Thanks guys,
Trying with 0002021, coding accepted.
Doing scan, but with errors :
Sunday,22,May,2011,21:34:34:03533
Control Module Part Number: 1K0 953 549 BP    HW: 1K0 953 549 BP
  Component and/or Version: J0527           051 0100
           Software Coding: 0002021
            Work Shop Code: WSC 01357 011 00200
           Additional Info: XXXXXXXXXXX E0221           002 0010
           Additional Info: Geraet 00200
                      VCID: 8127C981A3C9
2 Faults Found:
        014 - Defective - Intermittent
01044 - Control Module Incorrectly Coded
        000 -  -
Have I to start the engine or to run few meters ?
« Last Edit: May 22, 2011, 08:36:24 pm by plex »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: May 22, 2011, 08:36:36 pm »
0002022
is what I would say is correct
have you checked the MVB to see if the stalk functions work, and in the ECU to see if it gets the signal
