Author Topic: Need Help with Cruise Control Fitting Please  (Read 13331 times)
Offline plex
  • Awesome Rabbit !
Re: Need Help with Cruise Control Fitting Please
« Reply #15 on: May 22, 2011, 08:42:17 pm »
0002022
is what I would say is correct
have you checked the MVB to see if the stalk functions work, and in the ECU to see if it gets the signal
Eddie,
What is MVB please ?
Swiths on Steering Wheel works, I can do to confort fonctions, or hours, or RNS fonctions.
Stalk functions works like turn signal or front wiper (rear wiper is deleted)
About ECU signal, How can I see ?
Thanks so much !
« Last Edit: May 22, 2011, 08:50:14 pm by plex »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #16 on: May 22, 2011, 08:50:38 pm »
I made the last digit 1 as you said the wiper was removed.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #17 on: May 22, 2011, 08:51:42 pm »
Have you tried the coding Eddie suggests?
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: May 22, 2011, 09:00:17 pm »
have you driven the car above 25mph and tried it
Cluster and Key coding
Location Great Yarmouth
Offline plex
  • Awesome Rabbit !
« Reply #19 on: May 22, 2011, 09:02:33 pm »
Okay, I will drive the car and
Trying :
0002021 >> errors.
0002022 >> no errors & not work
0003022 >> errors
0003021 >> errors
0003041 >> errors
0003042 >> errors
Back in few minuts ^^
Okay it works now, AWESOME THANKS Eddie & vRStu
Just 10 meters, not any warning on board. Puting ON Switch but no light :(
Push + >> green light on :D Cruise function Ok.
But is there any way to have the green light on when switch is on please ?
In my MK5 TDI 2006, green light was on when swith is on ?
Thanks so much !!!
« Last Edit: May 22, 2011, 09:20:34 pm by plex »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #20 on: May 22, 2011, 09:03:28 pm »
I'm guessing you haven't totally removed the wiper so 0002022 will be correct.
Stu...
Offline plex
  • Awesome Rabbit !
« Reply #21 on: May 22, 2011, 09:25:15 pm »
Yes 0002022 works fine  :star:
What about swith and lights ?
Thanks so much !
« Last Edit: May 22, 2011, 09:28:43 pm by plex »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #22 on: May 22, 2011, 09:33:38 pm »
What switch and lights??
Is that the CC working now??
Edit - Just read your edited post above.  excellent.
I think the light depends on software versions in the CECM or Dash Insert.
I prefer the way yours is now.  I would leave the switch on at all times and then when you use CC you get the light on.
« Last Edit: May 22, 2011, 09:35:47 pm by vRStu »
Stu...
Offline plex
  • Awesome Rabbit !
« Reply #23 on: May 22, 2011, 09:58:19 pm »
Yes, actually CC works :)
And the CC works only when light in on.
CC can be "on" but no working, have to push - for working.
I think it will be good.
Many many many thanks !!!
