Author Topic: Rear wiper/washer failure.  (Read 1331 times)
Offline swgti
  • -Given: 28
« on: May 23, 2011, 11:40:14 am »
Done a quick search so sorry if this has been done a million times but I could only find stuff about the wiper going haywire, problem I've got is that it won't go at all, neither will the washer. I was wondering if it's the age old issue with the washer pipe coming off (had this on our Leon Cupra) but there's not even a buzz from the washer motor the whole thing is just dead. Front washers working fine and there's no leaks that I can see as yet. Are the washer and wiper both on the same fuse?
Any ideas?
Offline Golfgirl
Re: Rear wiper/washer failure.
« Reply #1 on: May 23, 2011, 01:13:37 pm »
Is the tailgate shut properly?
FOR SALE!
Offline gti265
« Reply #2 on: May 23, 2011, 01:20:21 pm »
about the fuse - if you look in your handbook it tells you whats connected to what fuses, then you can pull it out and check it :)
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline swgti
  • -Given: 28
« Reply #3 on: May 23, 2011, 04:18:39 pm »
You might have nailed it there, had the dog cage in at the time and it's a very tight fit so I'll check that later - cheers.
Offline deccae
« Reply #4 on: May 24, 2011, 11:52:10 pm »
had the same issue with my 2005 golf. with mine the boot light failed as well. Turned out to be broken wire in tailgate. Skoda dealer fixed it for about £100 i think.
Offline jonm
    • Staffs-VW
« Reply #5 on: May 25, 2011, 08:33:02 am »
I'm glad I don't have a rear wiper  :wink:
