Author Topic: RR day at PD Tuning on Saturday 16th July- Newcastle area  (Read 24190 times)
Offline heavyd
  • -Receive: 29
Re: RR day at PD Tuning on Saturday 16th July- Newcastle area
« Reply #120 on: July 22, 2011, 08:50:18 pm »
Just had an email and new map is being sent tomorrow amazing what difference Dsg map makes :fighting: :fighting:
Dave hasnt got a stage 2+ equivalent thats why I went to shark......
Shark map has loads more boost :driver:
Offline chungster
« Reply #121 on: July 22, 2011, 08:58:16 pm »
crikey its asking for 1.5bar all the way to 6k rpm!!
no wonder it's pulling some timing! Most maps would have started to tail off.
Think you should get an EGT gauge fitted.  :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #122 on: July 22, 2011, 09:07:40 pm »
Bear in mind the pdt map is stage 2 and the shark performance map is stage 3 so will have more boostbut see what you mean bout normally tailing off
Timing pull is much less on those logs dom, is that pre dsg remap or post. AFR bang on as well
« Last Edit: July 22, 2011, 09:21:12 pm by Janner_Sy »
Offline PDT
  • -Receive: 142
« Reply #123 on: July 22, 2011, 09:48:37 pm »
The addition of the Revo DSG map doesnt cause high timing pull,too much advance in the map is the problem here, or bad fuel maybe high intake temps?
When mapping any car I always try and get as close as possible to Zero timing pull by advancing timing bit by bit until you get an even 1-3 degrees of pull and then you know you are close to MBT (minimum best timing) and take out a little to be on the safe side, then the customer also has lots of headroom incase of high intake temps or needing to use a 95ron fuel, or both. A certain amount of mechanical sympathy is a good thing.
An engine pulling 8 on the timing wont make any more power than one pulling 1. When too much timing is pulled this can cause over retardation which in turn causes higher exhaust temps.
Looks like you might have another road trip Dom, and more data logging (go easy on the brakes  :evilgrin:)
I still dont offer a stg2+ (other than Revo)  for these very reasons, way too much work needs to go into them, far too much to expect a customer to be able to cope with understanding let alone expecting them to datalog and remedy the maps by trial and error by email. Superchips had the same issue with Bluefin, so they make the map stupidly safe with very little ignition advance and slightly rich fuelling (otherwise known as "vanilla flavoured mapping") there is a lot more that needs to go into a good stg2+ than a bit more boost, ignition timing and fuel :wink:
Did u get an overlay graph of the current stg2+ and our Stg2?
Offline heavyd
  • -Receive: 29
« Reply #124 on: July 22, 2011, 10:25:53 pm »
The last logs were fresh after the dsg map, on a colder day.
I'll wait and see what tomorrows map brings, at the end of the day, they did a good job the last time with improving the map, might need a road trip, but at least they have a dyno now :laugh:
The last time they added loads of timing, the dsg box was interfering and there wasnt any timing pull showing. When they upped the torque limiter the timing pull shot up, so I guess the same has happened again.
I have faith in Mikko!!! :notworthy:
I never did get the overlaid map Dave, I only got the 'hold 2 dyno sheets of paper against the window to see the difference' version :signLOL:
Offline PDT
  • -Receive: 142
« Reply #125 on: July 22, 2011, 10:31:01 pm »
Tracing paper.......
Offline chungster
« Reply #126 on: July 22, 2011, 10:39:33 pm »
or use excel and do a chart! its quite easy.....
something like this!
Offline PDT
  • -Receive: 142
« Reply #127 on: July 22, 2011, 11:13:48 pm »
Yes, you could do that. i just wanted to see doms attempt with tracing paper and various coloured crayons.  :grin:
Or I can send you one off the dyno if you like :happy2:
Offline heavyd
  • -Receive: 29
« Reply #128 on: July 23, 2011, 09:49:33 am »
did an excel graph. The two graphs were done in different gears, and the straps were also looser with the PDT map, and there were no gear calibrations done before the run either :wink:
Offline chungster
« Reply #129 on: July 23, 2011, 10:02:44 am »
Your line labels are wrong red/purple are torque curves blue/green are power curves
Offline Janner_Sy
  • -Receive: 113
« Reply #130 on: July 23, 2011, 10:16:08 am »
Why in different gears :confused:
Offline PDT
  • -Receive: 142
« Reply #131 on: July 23, 2011, 10:35:51 am »
We will test in 3rd and 4th, the gear the car makes more power in is the graph that will be kept.
Offline keano
  • -Given: 79
« Reply #132 on: July 23, 2011, 03:34:36 pm »
Ahh! Wondered why you were pointing out numbers to the lad on the Dyno computer!  :grin:
Offline Janner_Sy
  • -Receive: 113
« Reply #133 on: July 23, 2011, 03:36:51 pm »
So you don't go off the closest 1:1 ratio then, which from other vag tuners is i believe is 4th?
Offline heavyd
  • -Receive: 29
« Reply #134 on: July 23, 2011, 04:27:50 pm »
Theres already been that discussion on SCN Sy, theres always some controversy on a RR Day when people dont get what they expect, and it was the gear that was run for this one :signLOL:
Graph clearly shows that the midrange is a lot stronger, but early power and torque with the PDT will probably be due to the 3rd gear used, whereas shark was 4th. sorry, bit rusty at using excel, havent done graphs since 'A' levels 16yrs ago :stupid:
« Last Edit: July 23, 2011, 04:31:08 pm by heavyd »
