Author Topic: Best 25mm rear anti roll bar?  (Read 1111 times)
Offline Drapoon
« on: May 24, 2011, 11:11:16 am »
Bejeesus my head hurts.....
I've trawled the net and I'm still confused as to what is the best value rear bar for my mk5gti. Any feedback from people with Whiteline, H&R, BSH & Neuspeed bars would be great.
Any heads up for places offering a good deal at the mo would sway (get it?!) my decision also
cheers guys
Martin
Offline Carrera2RS
Re: Best 25mm rear anti roll bar?
« Reply #1 on: May 25, 2011, 01:08:28 pm »
I have 25mm Neuspeed and can confirm the fit and function are great. No squeeking or any problems at all. I run 25R,25F with the rear hard, the front soft (2 settings per bar)
Offline Drapoon
« Reply #2 on: May 25, 2011, 01:35:20 pm »
Many thanks fella
After not a lot of response I went for the 24mm adjustable whiteline offering which I will set to hard - I was really tempted by the neuspeed however the whiteline is better on the pocket. I hope that 1mm won't make all the difference!
I have 10mm spacers & kw coilovers fitted on 18" monzas which is causing a rear inner arch rub with body roll into tight bends hence sway bar needed
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #3 on: May 25, 2011, 03:56:56 pm »
If there's rubbing remove the spacers and/or go for both front and rear ARBs.
Have a look at this thread:
http://www.mk5golfgti.co.uk/forum/index.php/topic,18771.msg306377.html#msg306377
"You get what you pay for."
