Author Topic: Revision D Divertor Valve  (Read 2087 times)
Offline bird752
« on: May 24, 2011, 01:13:27 pm »
05 GTi.  Is there any way that I can check if I have the old diaprhram version fitted in my car without taking it to a garage?  I'm not mechanically minded and was wondering if there is an easy way to do this before I purchase the newer version.  I live in Suffolk if any one is available to help.  Cheers.
Re: Revision D Divertor Valve
« Reply #1 on: May 24, 2011, 03:38:20 pm »
Unfortunately you'll need to remove the dv to check its revision. This means you'll have to get under the car and remove the 3 holding bolts.
Offline martziniuk
« Reply #2 on: May 24, 2011, 04:20:55 pm »
I think if you jack it up there should be a part number on it which will end in B,C or D, but by doing this you may as well take it to a garage.
Offline mattypgolf
« Reply #3 on: May 24, 2011, 11:10:12 pm »
Where im suffolk arre you? on an O5 plate u will have an old version...mines an 08 going in to vw to be changed to new red d on thursday under warrenty
TR dsg, stage 1 r-tec map, bbs ch in gloss black, black roof and badges, colour coded, neuspeed hybrid intake, cat back exhaust..
Offline no golf clubs at all
« Reply #4 on: May 25, 2011, 06:17:34 am »
Is the dv underneath ? I thought there's a how to on here that says move air box to right or is that just on edition 30's?
http://www.mk5golfgti.co.uk/forum/index.php/topic,27003.0.html
« Last Edit: May 25, 2011, 06:19:23 am by no golf clubs at all »
Offline TrickGTI
« Reply #5 on: May 25, 2011, 07:29:38 am »
Yea they relocated the dv on the engines with the ko4 turbo ( edition 30 / Audi s3 / seat Cupra ) to the front of the engine and the normal gti there are bolted to the turbo. I think one of the vrs lads did a how to on relocating the dv to the front on the normal ko3 turbo engine.   :happy2:
2006 Tornado red GTI
« Reply #6 on: May 25, 2011, 07:32:13 am »
Bummer. It looks an easy self fit too.
 :sad1:
Offline Betty02
    • iBett
« Reply #7 on: May 25, 2011, 09:00:41 am »
Using my mates ramp at weekend to check my subframe bolts, tempted to use this time and give it a check over!
ADMIN NOTICE: Please do not use the site for advertising!
Offline bird752
« Reply #8 on: May 25, 2011, 11:34:14 am »
Matty, Im in Bury St Edmunds.
Offline MJR
« Reply #9 on: May 25, 2011, 12:39:06 pm »
I changed mine over to the rev "D" a while back, only took about half an hour.
Can be tricky getting the top bolt on and off  :happy2:
Offline gazon69
« Reply #10 on: May 25, 2011, 02:49:19 pm »
I changed mine a couple of months ago. not a nice job to do if your laid on your back old school style lol a bit fiddly but got there in the end.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #11 on: May 25, 2011, 04:00:30 pm »
Has to be removed to check i dont think you will manage to read the part number off without taking it off.  Only problem with that is you will need to refit the part and go through it all again or buy in advance not knowing if its needed, being an 05 and if its been in normal hands (not a forumite) then its probably on its original one and will be diaphram.  My 05 reg was MY06 I changed mine over despite no damage car felt different afterwards worthwhile doing and good to do it yourself.
