Author Topic: Not convinced my Ed30 GIAC Map is as it should be  (Read 21378 times)
Re: Not convinced my Ed30 GIAC Map is as it should be
« Reply #45 on: June 04, 2011, 08:03:09 pm »
Has the timing belt been done yet?
Could have been fitted out of synch!
Offline PDT
  • -Receive: 142
« Reply #46 on: June 04, 2011, 09:04:41 pm »
Car made 226bhp with stock map on, only had issues when asked to make more power.
Boost values are fine, fuelling is fine, fuel pressure is fine but pulls a blanket -7. Degrees under load and only achieves 170-180% load. But in stock form its fine.
Looking over all of the logs later, will see if I can spot anything, is very strange though!
« Reply #47 on: June 04, 2011, 09:07:00 pm »
i had the very same problem a few years ago and it turned out one of the pipe to my forge dv was wrong way around
Offline PDT
  • -Receive: 142
« Reply #48 on: June 04, 2011, 09:09:40 pm »
Im sure Chris will confirm, but car is 100% stock.
Offline heavyd
  • -Receive: 29
« Reply #49 on: June 04, 2011, 10:40:29 pm »
I know of a couple of 1.8T's that had the same problem, my brother had to have his fitted 3 times at a local vw specialist, a mate of mine had his done twice a a seat dealers, then eventually paid out for a vw dealers to fit it as it was a tooth out aswell.
« Reply #50 on: June 05, 2011, 12:14:20 am »
It is just that I know of a couple of cars that had been having power issues that both had 1 tooth out on the timing belt like you say and both were fine after.
Offline robdf2
« Reply #51 on: June 05, 2011, 10:03:16 am »
im really interested in this thread , my car has the exact same issues , in stock form makes spot on power 240 bhp but as soon as my map is on then i can only manage timing of 3 before it starts getting pulled , i have had a new timing belt fitted , wonder if this could be my problem?
2008 Chrono yellow Cupra
Offline chris s
« Reply #52 on: June 05, 2011, 08:03:42 pm »
Yeah my car is 100% stock other than the GIAC stage 1 map I did have on it.... I replaced the DV a couple of weeks ago, but only to the newer VAG type D model so effectively stock.
Thanks for the comments so far.... as you can imagine I'm really keen to get the car back on a map ASAP
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline robdf2
« Reply #53 on: June 05, 2011, 08:43:12 pm »
wheres your car now mate?
have you got any logs you can post up?
Offline chris s
« Reply #54 on: June 05, 2011, 09:01:03 pm »
Hi - here's a log Dave sent me after being on his Dyno:
   Group A:   '115            Group B:   '020            Group C:   '230
      Engine Speed   Engine Load   Boost Pressure   Boost Pressure      Cylinder 1 Ignition   Cylinder 2 Ignition   Cylinder 3 Ignition   Cylinder 4 Ignition      Rail Pressure   Rail Pressure   Rail Pressure
   TIME         (specified)   (actual)   TIME   Angle Delay   Angle Delay   Angle Delay   Angle Delay   TIME   (specified)   (actual)   Difference
Marker   STAMP    /min    %    mbar    mbar   STAMP   °KW   °KW   °KW   °KW   STAMP    bar    bar    bar
   0.23   1640   106   1620   1330   0.37   -3.8   -2.3   -4.5   -4.5   0.11   91.22   91.13   0.09
   0.62   1600   106.8   1610   1330   0.74   -6   -2.3   -4.5   -4.5   0.49   95.04   95.14   -0.1
   1.04   1640   106.8   1620   1340   1.16   -6   -1.5   -4.5   -4.5   0.88   99.14   98.84   0.3
   1.43   1640   108.3   1620   1340   1.55   -6   -1.5   -4.5   -4.5   1.29   102.15   102.92   -0.77
   1.8   1640   107.5   1620   1350   1.94   -6   -1.5   -3.8   -4.5   1.68   102.69   103.03   -0.34
   2.19   1640   108.3   1640   1350   2.32   -6   -1.5   -3.8   -4.5   2.07   102.8   102.92   -0.12
   2.58   1920   107.5   1950   1380   2.71   -6   -1.5   -3.8   -4.5   2.46   105.04   104.36   0.67
   2.97   2160   113.5   2220   1440   3.1   -6   -1.5   -3.8   -4.5   2.83   108.92   109   -0.08
   3.35   2400   124.1   2400   1560   3.49   -6   -1.5   -3.8   -3.8   3.22   109.86   110.32   -0.46
   3.74   2640   136.1   2420   1730   3.86   -6   -1.5   -3.8   -6.8   3.61   109.97   110.46   -0.49
   4.13   2920   154.9   2310   1970   4.25   -5.3   -1.5   -3.8   -6.8   4   109.99   110.17   -0.18
   4.52   3080   186.5   2360   2330   4.64   -5.3   -1.5   -3.8   -6.8   4.37   109.99   110.36   -0.37
   4.89   3400   191.7   2300   2510   5.03   -5.3   -1.5   -3.8   -6.8   4.77   109.99   108.84   1.15
   5.28   3640   191.7   2260   2470   5.41   -5.3   -1.5   -3.8   -6.8   5.16   109.99   103.16   6.83
   5.67   3840   185.7   2250   2270   5.8   -5.3   -1.5   -3.8   -6.8   5.55   109.99   102.48   7.51
   6.06   4040   177.4   2260   2210   6.19   -5.3   -1.5   -3.8   -6.8   5.92   109.99   108.83   1.16
   6.44   4280   176.7   2290   2210   6.58   -5.3   -1.5   -3.8   -6.8   6.31   109.99   112.83   -2.84
   6.82   4560   181.2   2320   2230   6.95   -5.3   -1.5   -3.8   -6.8   6.7   109.99   108.41   1.58
   7.21   4800   180.5   2350   2250   7.34   -5.3   -1.5   -3.8   -6.8   7.09   109.99   110.59   -0.6
   7.61   5040   178.9   2400   2300   7.73   -5.3   -1.5   -3.8   -6.8   7.46   109.99   110.57   -0.58
   7.98   5280   181.2   2410   2330   8.12   -5.3   -1.5   -3.8   -6.8   7.85   109.99   111.19   -1.2
   8.37   5480   181.2   2360   2340   8.49   -5.3   -1.5   -3.8   -6.8   8.24   109.99   109.39   0.6
   8.76   5720   181.2   2330   2310   8.88   -5.3   -1.5   -3.8   -6.8   8.63   109.99   110.54   -0.55
   9.15   5960   176.7   2230   2260   9.27   -5.3   -1.5   -6.8   -6.8   9.01   109.99   110.19   -0.2
   9.52   6160   171.4   2240   2240   9.67   -5.3   -1.5   -6.8   -6.8   9.4   109.99   105.62   4.37
   9.91   6320   167.7   2210   2180   10.04   -5.3   -1.5   -6.8   -6.8   9.79   109.99   111.35   -1.36
   10.31   4880   55.6   580   1920   10.43   -5.3   -1.5   0   0   10.18   99.89   94.68   5.21
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline robdf2
« Reply #55 on: June 06, 2011, 10:52:20 am »
those logs look nearly identical to mine  :confused:
i will post mine up later tonight for you.
Offline chris s
« Reply #56 on: June 06, 2011, 11:15:47 am »
OK - not sure what is going on as to the best of my knowledge my timing belt has not been changed
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline robdf2
« Reply #57 on: June 06, 2011, 11:20:25 pm »
Heres my log from tonight:
Code: [Select]
G001 G020 G020 G020 G020 G102 G115 G115 G230 G230
TIME Group 1 - Field 0 Group 20 - Field 0 Group 20 - Field 1 Group 20 - Field 2 Group 20 - Field 3 Group 102 - Field 3 Group 115 - Field 2 Group 115 - Field 3 Group 230 - Field 0 Group 230 - Field 1
STAMP Engine Speed Cylinder 1 Ignition - Angle Delay Cylinder 2 Ignition - Angle Delay Cylinder 3 Ignition - Angle Delay Cylinder 4 Ignition - Angle Delay Median - injection timing Boost Pressure - (specified) Boost Pressure - (actual) Rail Pressure - (specified) Rail Pressure - (actual)
/min ḞKW ḞKW ḞKW ḞKW ms mbar mbar bar bar
0.01 1800 0 0 0 -3 3.31 1680 1090 82.92 82.75
0.27 2000 0 0 0 -2.3 3.31 1790 1160 91.43 91.17
0.52 2080 0 0 0 -1.5 3.57 1950 1240 99.6 100.2
0.79 2200 0 0 0 -3 3.83 2130 1320 106.91 107.03
1.03 2320 0 0 0 -3 3.83 2180 1420 114.39 114.71
1.28 2440 0 -3 0 -4.5 4.08 2240 1530 120.82 119.88
1.51 2560 0 -3 -3 -4.5 4.34 2270 1670 123.93 123.88
1.77 2760 0 -3 -3 -4.5 4.84 2300 1860 124.72 124.21
2.02 2920 -3 -3 -3 -4.5 5.36 2310 2100 124.92 124.92
2.28 3120 -3 -3 -3 -4.5 5.87 2320 2240 124.97 124.99
2.53 3320 -3 -3 -3 -4.5 6.12 2320 2350 124.99 126.35
2.78 3480 -3 -3 -3 -4.5 6.63 2330 2390 125.13 124.24
3.02 3640 -4.5 -3 -3.8 -4.5 6.88 2320 2430 125.24 123.55
3.27 3840 -4.5 -3 -3.8 -4.5 6.88 2330 2360 125.27 120.22
3.53 4040 -4.5 -3 -3.8 -4.5 6.63 2350 2300 125.5 121.52
3.78 4200 -4.5 -2.3 -3.8 -3.8 6.63 2370 2300 125.73 122.25
4.04 4400 -4.5 -2.3 -3 -3.8 6.88 2390 2330 125.73 121.26
4.28 4520 -4.5 -2.3 -3 -3.8 6.88 2380 2340 125.73 119.46
4.53 4720 -4.5 -2.3 -4.5 -3.8 6.88 2370 2360 125.74 114.09
4.78 4880 -4.5 -2.3 -4.5 -3.8 6.88 2380 2370 126.1 118.85
5.04 5040 -4.5 -2.3 -4.5 -3.8 6.63 2380 2380 126.76 122.31
5.29 5200 -4.5 -2.3 -4.5 -3.8 6.63 2370 2350 127.28 124.54
5.55 5400 -4.5 -2.3 -4.5 -3.8 6.38 2370 2310 127.42 125.31
5.79 5560 -4.5 -2.3 -4.5 -3.8 6.38 2370 2320 127.47 123.89
6.05 5640 -4.5 -2.3 -4.5 -3.8 6.38 2370 2320 127.49 125.99
6.29 5840 -4.5 -2.3 -4.5 -3.8 6.38 2330 2300 127.49 125.65
6.56 5960 -4.5 -2.3 -4.5 -3.8 6.38 2280 2280 127.49 125.59
6.81 6120 -4.5 -2.3 -4.5 -3.8 6.12 2280 2250 127.49 125.91
7.07 6280 -4.5 -1.5 -4.5 -3.8 5.87 2280 2220 127.49 125.68
7.33 6440 -4.5 -1.5 -3.8 -3 5.87 2290 2220 127.49 126.72
7.6 6560 -4.5 -1.5 -3.8 -3 5.87 2290 2220 127.49 126.75
7.85 6680 -3.8 -1.5 -3.8 -3 5.61 2290 2210 127.49 126.5
8.13 6840 -3.8 -0.8 -3.8 -3 5.61 2300 2190 127.49 127.31
8.38 6960 -3.8 -0.8 -3.8 -3 5.1 1830 2250 127.49 126.93
8.66 7040 -3.8 -0.8 -3.8 -3 4.59 1510 2330 127.49 128.23
what i am still also trying to trace and cure is why my fuel pressure drops then comes back up again see 4520 rpm   :confused:
« Last Edit: June 06, 2011, 11:22:31 pm by robdf2 »
Offline PDT
  • -Receive: 142
« Reply #58 on: June 07, 2011, 10:18:00 am »
Hi Chris,
I have some coilpacks and plugs coming in stock later this week, think it might be worth a try changing them and reflashing a stg1 map, if only for a road test. If they dont help I can swap back to your originals, no charge for the parts.
Offline chris s
« Reply #59 on: June 07, 2011, 01:21:47 pm »
Hi Dave - I actually have some NGK Iridium plugs at home, but forgot to bring them on Saturday.  I have read on various forums that the plugs have fixed similar problems but with out knowing why or how.
I did have one thought... when you flashed my car with the REVO trail, did you try and adjust the timing settings?
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
