Author Topic: airbag light after RCD510 install  (Read 1538 times)
Offline parks
  • Red ED30 No. 1778 Detailing World member
« on: May 25, 2011, 01:30:05 pm »
afternoon,
after refitting my RCD510 to stop rattling my computer midline says airbag fault when turning on the engine...
any ideas?
 hopefully this can be sorted by VCDs...
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Re: airbag light after RCD510 install
« Reply #1 on: May 25, 2011, 01:46:27 pm »
Assuming it's all put back together correctly then yes, vcds will clear the fault code.
Offline alexperkins
  • -Receive: 99
« Reply #2 on: May 25, 2011, 01:52:44 pm »
Did you take the top piece off and disconnect the Passenger Airbag light and put the ignition on before reconnecting it?
Offline parks
« Reply #3 on: May 25, 2011, 01:54:03 pm »
Yes, thats correct!
makes sence, as last time i didnt disconnect it and the fault didnt show!
Offline alexperkins
  • -Receive: 99
« Reply #4 on: May 25, 2011, 01:55:17 pm »
VCDS and just clear the fault code on Airbags and itll go away  :happy2:
