Author Topic: BT Master Socket Problem  (Read 1832 times)
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« on: May 26, 2011, 03:21:18 pm »
Can anyone help. My BT cable comes into the house there are four wires black , blue , white and green. I have a non nte5 master socket and want to attach these cables to it. I just want the socket to plug a phone into only. Can't get anything off internet!!!!!!!
Re: BT Master Socket Problem
« Reply #1 on: May 26, 2011, 04:03:15 pm »
You only need to wire the blue and blue/white wires to 2 and 5 respectively on the socket for the phone to work.
http://www.dslzoneuk.net/socket.php?type=html
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #2 on: May 26, 2011, 04:35:51 pm »
But i only have the wires mentioned. I do not have multicoloured wires ! I am getting very frustrated ! All internet wiring diagrams i have found have different bt wire colours to me
« Reply #3 on: May 26, 2011, 04:39:06 pm »
You should normally have blue/white, green/white, orange/white and brown/white off the top of my head.
If you have the time and patience try 2 of the 4 wires in all the various combinations. If you are adding an extension from the master socket you will need to extend 2, 3 and 5 so it will ring.
HTH.
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #4 on: May 26, 2011, 05:33:40 pm »
No as i dont have multi coloured wires!
Offline Gti_Mad
« Reply #5 on: May 26, 2011, 05:52:33 pm »
I had a phone line installed yesterday try the blue and the white  :happy2:
Offline apollo13
  • -Receive: 47
« Reply #6 on: May 26, 2011, 06:07:19 pm »
Blue and white is usually bt's first choice.
If for any reason that doesnt work try orange and white and then green and white and then finally black and white.
« Reply #7 on: May 26, 2011, 06:31:31 pm »
Did you miss this?
HTH.
:popcornsoda:
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #8 on: May 27, 2011, 10:55:48 am »
Sorted :happy2:
Was the Black and Green !
Offline QD MBE
  • -Receive: 102
« Reply #9 on: May 27, 2011, 05:13:20 pm »
« Last Edit: May 27, 2011, 05:16:58 pm by QD »
Offline alexperkins
  • -Receive: 99
« Reply #10 on: May 28, 2011, 01:43:32 pm »
Wiring into the house into the Master socket is often a different colour to the internal wiring which employs multi coloured wires.
