Author Topic: Stalling issue - FIXED, YEAY!!!!  (Read 35423 times)
Re: Stalling issue - FIXED, YEAY!!!!
« Reply #45 on: June 18, 2011, 04:41:27 pm »
about £12 mike
Bloody 'ell ordered cambelt kit off Dave at Sere, wish Id thought to stick one on the order.  Cant take long to change?
Offline Gti_Mad
« Reply #46 on: June 18, 2011, 04:50:37 pm »
10mins at most mate aslong as u can get underneath 2 do it
Offline drexel75
« Reply #47 on: June 18, 2011, 08:04:54 pm »
I had the same problem in my A4. Was at a specialist from Monday to Thursday before he spoke to another specialist that had come across it before. Ordered the part, fitted it on the Friday and the car was as sweet as a nut after that. We had to replace the fuel filter too because initially he thought that was the problem and when he tried to clean it one of the plastic parts snapped on it. Was full of crud so replacing it seemed the safer option. Glad to hear you got yours sorted.
At what mileage did you swap your fuel filter?  Is it the filter normally found under the sill.  I rang for a price from my local dealer and they said dont bother its a long life filter?
I was talking rubbish. It was the fuel pump that was changed as well as the fuel pressure sensor. Sorry to be misleading.
« Reply #48 on: June 18, 2011, 08:11:58 pm »
Okidoke, no worries.  Dont let it happen again  :P
WILLZIE
« Reply #49 on: July 08, 2011, 06:56:05 pm »
Has anyone got the part number for this G247 Fuel pressure sensor or known as Low pressure sensor!.. if thats correct??
My issue is mine has just gone to the dealers and it has come up with this fault, or several, one including a fuel rail fault or code!.... is this normal to bring other faults up on the dianostics due to just this one 'Low pressure sensor'...???
any advice much appreciated.  :surprised:
« Reply #50 on: July 08, 2011, 10:01:50 pm »
You could get the following error codes with a faulty low fuel pressure sensor aka thrust sensor
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent - MIL ON
004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
P129F - 001 - Upper Limit Exceeded – Intermittent
Offline baldwined30
« Reply #51 on: July 09, 2011, 11:47:41 am »
Anyone had there HPFP making a higher pitched noise? its been on for about 8k now and i can hear it louder now i have a twin take? any ideas?
Ed30
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #52 on: June 16, 2020, 01:19:42 am »
Just to add a correction: G247 is the high fuel pressure sensor on the fuel rail.  You were directed correctly to the low fuel pressure sensor which is on the HPFP, but it is the G410.
