Author Topic: Oil Usage  (Read 10677 times)
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Oil Usage
« Reply #15 on: May 28, 2011, 05:04:01 pm »
That's because the light is a 'you're about to do engine damage' light, not a 'top up your oil reminder' light. Dash lights are warnings that something's not right, the oil level may be well below minimum before the oil pressure light illuminates.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Oil Usage
« Reply #16 on: May 28, 2011, 06:55:52 pm »
I've said on many occasions, if you top up the oil to the max mark the engine will burn it off until it finds a satisfactory level which is normally between the two marks.
« Last Edit: May 28, 2011, 07:12:17 pm by vRStu »
Stu...
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Oil Usage
« Reply #17 on: May 28, 2011, 10:02:42 pm »
Sounds good advice, can't easily over fill then?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Oil Usage
« Reply #18 on: May 29, 2011, 01:23:07 pm »
Not true - there are two lights - oil pressure and oil level.  Certainly on my 05 plate.  If you check the manual it tells you.  A message also comes up in the MFD to say check level.  The message if the pressure is low is to stop engine.
Agreed in principle you shouldn't rely on this but there are definitely two different warnings.
Sepang Blue S4 BE Avant
