Author Topic: How do I paint my parts? :D  (Read 4502 times)
Offline big al
« on: May 27, 2011, 03:12:08 pm »
Hi guys, going to try and save a few £ and paint my engine cover myself.
Have seen some people do small parts like steering wheel inserts.
was just wondering how to do it, and what are the best products to get (think I am limited to Halfrauds sprays)
How much do I need to sand?
Do I sand,then prime,then sand again and then top coat?
Any advice would be appreciated.
Offline flinty
Re: How do I paint my parts? :D
« Reply #1 on: May 27, 2011, 10:04:00 pm »
start with sanding 240-400-600 grit,
primer
sand primer 600grit
paint then no need to sand
then if using metallic paint if you sand the paint itll look crap so best bet is if you get runs sand them out then repaint then laquer, then sand with 1000 -1500 wet  then polish to a shine
Offline big al
« Reply #2 on: May 27, 2011, 11:19:49 pm »
That's great thanks for the tip.
Where would you recommend I get the paint from?
Is there any difference depending where I buy it or is it all the same really?  :happy2:
Offline flinty
« Reply #3 on: May 28, 2011, 07:37:10 am »
halfrauds is as good as any for rattle cans
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #4 on: May 28, 2011, 09:16:32 pm »
Patience is the key, dust free environment and rub down after each coat :happy2:
Offline Wildman10
« Reply #5 on: May 28, 2011, 09:53:58 pm »
If you want to match the body colour then go to VW - very reasonably priced & the quality is fantastic.
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #6 on: May 28, 2011, 10:38:25 pm »
So Vw do spray paint??
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline big al
« Reply #7 on: May 29, 2011, 12:32:07 am »
Only place I have is the garden, not the most dust free place in all honesty, maybe try in the utility room instead.
Offline alexperkins
  • -Receive: 99
« Reply #8 on: May 29, 2011, 09:44:13 am »
They do indeed mate
Offline bodger00
  • -Receive: 20
« Reply #9 on: May 29, 2011, 10:39:13 am »
Al VW paint is a great match. Just a warning about spraying in the house....it goes everywhere! Don't tell the Mrs :evilgrin:
Offline alexperkins
  • -Receive: 99
« Reply #10 on: May 29, 2011, 10:57:09 am »
:signLOL:
Offline big al
« Reply #11 on: June 08, 2011, 12:24:47 pm »
Had a go at spraying the engine centre strip yesterday, found out the hard way that I had not smoothed it enough, the primer showed up every rough part that I had missed (though it does make it easier to see that I have smoothed it enough this time, just killing me fingers as the sand paper gets a lot of friction, and also using up loads as the primer sticks all over the sandpaper. Is there a thicker primer I could get that would fill all the small cracks/rough parts that i have missed?
Offline alexperkins
  • -Receive: 99
« Reply #12 on: June 08, 2011, 12:29:27 pm »
Filler primer and a lighter grade of paper is advisable
Offline big al
« Reply #13 on: June 08, 2011, 04:00:34 pm »
http://cgi.ebay.co.uk/HYCOTE-FILLER-PRIMER-SPRAY-PUTTY-400ml-/150587063142?pt=UK_Body_Shop_Supplies_Paint&hash=item230fb03b66#ht_3052wt_905
would that stuff be any use? I have up to 600grit wet and dry sand paper, think that is fine enough?
Offline alexperkins
  • -Receive: 99
« Reply #14 on: June 08, 2011, 04:03:20 pm »
That looks ok.
Halfords do sell a UPOL one which is quite good
Get 1200 grit - 600 is a bit course
