Author Topic: Boost Revo Stage 1 ED30  (Read 1307 times)
Offline _Nathan_
    • Race Data Systems - Motec Cosworth Aim Racelogic
« on: May 29, 2011, 06:12:34 pm »
Anyone know what the requested and actual boost is on an ED30 stage 1?
Also should requested fuel rail pressure really be 130 - can the stock HPFP even provide that (mine can't).
« Last Edit: May 29, 2011, 10:32:27 pm by _Nathan_ »
E90 M3, E46 CSL Race car
Re: Boost Revo Stage 1 ED30
« Reply #1 on: May 31, 2011, 07:19:55 pm »
It depends on how long it is requesting it.
Put some of your logs up and someone clever not me can compare them with some 2+ logs.  :smiley:
Offline chungster
« Reply #2 on: May 31, 2011, 07:40:21 pm »
around 1.3-1.4 bar from memory.....
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: May 31, 2011, 08:47:12 pm »
I'd say you need to log other values too e.g. ignition delay to see what else is going on.
the boost levels seem a bit low tbh even for stage 1 (1300 mbar is about 19psi) where Im easily at 20+ (24 on guage) in the mid range.
but the revo are the experts....
Red ED35 5dr DSG
BLOG | BUILD
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: June 01, 2011, 12:13:57 pm »
my mid range is higher but my 6k value  is lower  :signLOL:   (ill go dig out the plots later tonight)
OEM all but the map.
130 bar from fuel pump should be achievable once its spinning above 4k rpm
let us know what REVO say  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
