Author Topic: May '11 Passat CC - RNS 510 - Full post code support  (Read 2132 times)
Offline rwn45549
« on: May 31, 2011, 01:37:33 pm »
Hi,
I have just taken delivery of a brand new Passat CC, was build first week in May.
The RNS 510 unit I have will only do 5 digit post codes. v7 Maps were supplied by with the car.
Is there a newer version of firmware avaliable which will allow 7 digit UK post codes?
I do not know which firmware it's currently running.
Any help would be much appreciated!
Richard
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: May '11 Passat CC - RNS 510 - Full post code support
« Reply #1 on: May 31, 2011, 02:05:05 pm »
Given it's brand new I'd be inclined to enquire at the dealer about updating to the latest firmware, to support speed camera & full postcode. If you have access to VCDS you can scan the nav unit to see what firmware it's running.
Offline alexperkins
  • -Receive: 99
« Reply #2 on: May 31, 2011, 02:25:02 pm »
If its brand new, it should be on around 2760 with maps 7333 or newer for full 7 digit.
Offline rwn45549
« Reply #3 on: May 31, 2011, 04:20:18 pm »
I just noticed the RNS 510 manual that came with the car says 11.2010 Edition on the front.
Does this mean anything?
I will enquire with the dealer regarding the firmware.
Offline alexperkins
  • -Receive: 99
« Reply #4 on: May 31, 2011, 04:21:15 pm »
Thats just the revision of the manual. Not of much use really
Offline rwn45549
« Reply #5 on: May 31, 2011, 04:30:48 pm »
Dealer wasnt very helpful, they said it hasnt been released for the Passat CC yet!
VW customer service were a little more useful, but they still havent given me a solution.
I'm a bit apprehensive doing anything myself seeing as i've only had the car since Friday!
Offline alexperkins
  • -Receive: 99
« Reply #6 on: May 31, 2011, 04:34:52 pm »
If you know someone with VCDS they can scan it and enable the secret menu to determine the map and firmware version
