Morty, there has been some rubbing to the drive shafts?
You have fitted the S3 arms and spindles. Hard to see,
but have you fitted the correct nut to the steering rod?
I did the mistake first to use the old standard GTI nut, that
was not suited for the alloy spindles, so I had to retrofit the
sorrect S3 nut. Same for the ball joint.
I wouldn't lift the car under the rear arm bushing mount again.
