Author Topic: NEW: RS3 / TT upper strut mount + brake ventilation element  (Read 43856 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: NEW: RS3 / TT upper strut mount + brake ventilation element
« Reply #90 on: May 14, 2012, 09:25:40 am »
Where I live it's 11:25. So no excuses for me  :grin:.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #91 on: May 14, 2012, 04:24:29 pm »
The underside of the engine bay of a street car is a high pressure area. Remember
the front subframe ist the lowest part of our cars which slows the air flow. Even more
the air flowing though the engine bay (which entered via the radiator) has to leave
it somewhere. The flanks/sidewalls of the car are low pressure areas. This is common
knowledge and can easily be read in a subject book about aerodynamics.
So the air flow has a V-shape like pattern towards the wheel wells. The RS3/TT-RS
vent directions this flow to the brake discs (or to the dustshields if still in place).
Still common knowledge.  :wink:
From my understanding the RS3/TT-RS vent can not ensure it has a full effect if the
directed air flow is blocked by the dust shield.  :wink:
I never had any issues in the wet or even in the winter with lots of salt on the road
if you fear this.
At least if you have slotted, drilled or J-hooked rotors I don't expect running without
dust shields to be problematic at all.
 :drinking:
"You get what you pay for."
« Reply #92 on: July 04, 2012, 11:08:57 pm »
I will have these top mounts for sale very soon.
Rs3. Although ended up identical to my Cupra ones.  Stiffer than normal Gti and perhaps ed30, this thread should confirm.
Will make a fs when they're taken off the car for fully adjustable ones very soon
 :smiley:
Offline stubert
« Reply #93 on: March 20, 2014, 07:33:57 pm »
Resurrected this thread to save starting a new one as there's some great information in it.
I took delivery of my RS3/TTRS air slides today with associated bolts, nuts and spacer tube.
I haven't seen any pics of them fitted to MK5's that have the welded lower arms. And surprise surprise, the slides don't fit.
Seems I could have cut them as suggested earlier in this thread but I don't fancy butchering them.
I'm keen to get some alloy arms so will keep them until then.
Offline metaljay
  • Scirocco R Owner
« Reply #94 on: March 20, 2014, 07:38:54 pm »
I also am looking for a set of alloy arms atm, awesome have a set mind you...
