July 02, 2024, 07:07:36 pm
All Things Mk5
Technical Workshop
Suspension top mount advice - what do i need to order?
Topic: Suspension top mount advice - what do i need to order? (Read 4566 times)
mikegemmill
Just Arrived
-Given: 0
-Receive: 0
June 02, 2011, 10:48:39 am »
I've finally ordered some coilovers for my mk5.... went for the Jamex kit so fingers crossed it works out ok.
I've been told to change the top mounts while I'm at it but unsure which part I need?
2 FT STRUT TOP MOUNTS GOLF MK5 POLO 9N2 9N CADDY SEAT AUDI SKODA
£17.57
OR
2 AXIAL GROOVED STRUT TOP BEARINGs GOLF MK5 POLO 9N2 9N CADDY ++
£18.66
Anyone know?
Thanks.
alexperkins
Just look at my post count
-Given: 7
-Receive: 98
Re: Suspension top mount advice - what do i need to order?
Reply #1 on:
June 02, 2011, 10:53:56 am »
The groove bearings
go into
the top strut mount rubbers
Would advise to get OEM ones from VW too as copy parts of this type are often poor quality and wont last.
mikegemmill
Just Arrived
-Given: 0
-Receive: 0
Reply #2 on:
June 02, 2011, 11:14:47 am »
Thanks Alex, I'll go to VW then.
Should i replace both parts then? As far as I'm aware neither has failed, I just thought it'd be a good opportunity to take the precaution.
alexperkins
-Given: 7
-Receive: 98
Reply #3 on:
June 02, 2011, 11:29:32 am »
If you are doing the top mounts, its generally good practice to do the groove bearings too
dub singh
Always Involved
-Given: 12
-Receive: 13
Snakebite Chasers...
Reply #4 on:
June 05, 2011, 07:28:07 pm »
Got my coilovers put on 3months ago, recently developed a knocking sound on full lock... found out its due to the top mount bearings that have perished..
Any diea how much VW would charge for them?
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Saint Steve
Reply #5 on:
June 05, 2011, 07:30:10 pm »
Id check your sub frame bolts are tight 1st before shelling out for those..
Known issue on the mk5
or Could be a steering rack issue perhaps?
George
Always Involved
-Given: 8
-Receive: 8
Reply #6 on:
April 21, 2012, 11:01:57 am »
Is there any point in doing the rubber mounts when fitting new springs? Normally springs are just swapped without changing any parts, but I thought it would be good practice to fit new bearings and it may stop the creaking I have when turning slowly on full lock
All Things Mk5
Technical Workshop
