Author Topic: Anyone tried these??  (Read 916 times)
GTIStevie
« on: June 04, 2011, 10:46:34 pm »
Re: Anyone tried these??
« Reply #1 on: June 04, 2011, 10:48:46 pm »
You could pick up some proper xenons for not much more.....
GTIStevie
« Reply #2 on: June 04, 2011, 10:57:12 pm »
Are the demons easy to fit though don't you need sensors for level adjustment???
Do they need to be coded??
« Reply #3 on: June 04, 2011, 11:02:11 pm »
If you mean xenons then the fitting process is the same other than the Kufatec pin adapter. The lights have levellers built in that can be manually adjusted.
GTIStevie
« Reply #4 on: June 04, 2011, 11:08:39 pm »
Then don't u need to fit washers??
