Author Topic: Rns510 canbus upgrade?  (Read 2313 times)
Offline JCMUSCLE
« on: June 06, 2011, 03:36:54 pm »
Have a 2007 gti dsg
Comes with standard rcd300 and looking at a 2011 rns510 v c
Read threads about battery drainage issues?
How much would it cost to upgrade the canbus ?
MKV GTI DSG = Gone
DPB MKV R32 DSG - ZOLDERS - LEATHER - RNS510 - MDI - XENONS - OEM BLUETOOTH - F1 PADDLES - MK6 CLIMATE CONTROL W AQS
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Rns510 canbus upgrade?
« Reply #1 on: June 06, 2011, 05:16:42 pm »
Hi
Where are you located?
Cluster and Key coding
Location Great Yarmouth
Offline alexperkins
  • -Receive: 99
« Reply #2 on: June 06, 2011, 05:22:35 pm »
Have a 2007 gti dsg
If its a 2007, you may well be ok. What month was it - generally anything after March is fine  :happy2:
Offline JCMUSCLE
« Reply #3 on: June 06, 2011, 06:13:00 pm »
Located in cambridge
Yes was made/registered march 07
MKV GTI DSG = Gone
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: June 06, 2011, 06:17:53 pm »
Ideally you need to have your car scanned with Vag-com so you can see what you have. As said earlier you may be lucky and don't need to upgrade.
If you buy the gateway from the dealer new then it would cost around £130 or you can buy one from ebay for less
You will need someone with Vag-com to code it
I'm not too far away in Great Yarmouth if you need it fitted and coded
Offline JCMUSCLE
« Reply #5 on: June 06, 2011, 06:23:03 pm »
Ok thanks il keep that in mind
Whats the oldest version gateway that will take the rns510 without battery probs?
What do i ask for exaxtly at the stealers?
Any specific module/canbus, newer the better i presume?
MKV GTI DSG = Gone
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: June 06, 2011, 06:50:06 pm »
K version and above
I would stick with the newer ones
Offline N13KKF
« Reply #7 on: June 24, 2011, 12:45:25 am »
Its Really Revision L or above some Revision K will be fine but others will not. Vw charge about £150 for a can gateway. i can supply gateways for £100 plus fitting. im near Romford if its any use
Nick
Rns510 ver C LED-£550, Rns510 ver B-£460, Video In Motion £45, Genuine Full VCDS
Offline DaveR77
    • UK-MKIVS.net
« Reply #8 on: June 24, 2011, 08:25:25 am »
Mine is Jan 07 (K) and was fine, I'd definitely try it first before buying a new gateway
Offline N13KKF
« Reply #9 on: June 24, 2011, 08:53:20 am »
yeah try it first. you could always run modified fw2760 giving you no battery drain and still having 7 digit postcode
