Author Topic: Need Help ASAP  (Read 1013 times)
Offline Phil Miller
  • -Given: 86
Need Help ASAP
« on: June 07, 2011, 08:29:33 pm »
Hi all, now ive got an epic problem, which i  have bought on myself so im in need of HELP asap
Now ive got on route a kufatec TPMS kit and have read thro a how to fit it guide that was posted up on here, now ive borrowed VCDS off a friend due to having an ESP light on, i sorted the esp light not a problem so after work i was bored and the tpms guide said you can code it before fitting the wiring it said to put in the new code as 0004738, here is my first mistake, my code was 0021121 yet in the guide it said 0021122 :surprised: so after putting the code in and seeing the tpms light on my dash i was getting ready to pat myself on the back when i heard a beep and saw the ABS light flashing with the handbrake light, so i checked the codes stored and it had a mechanical fault, i earsed it, so i re entered the code as 0021122 which stopped the beep and flashing handbrake light and ABS, but then i remembered id taken a photo of the code before i started and it was in fact 0021121 so i put the correct code in and now the ABS light is on full time here is part of the scan i have just taken this code comes back as soon as it is deleted
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0004737
   Shop #: WSC 01279 785 00200
   VCID: 3A55FC230CCF
1 Fault Found:
01486 - System Function Test Activated
            000 -  -
now if any of the above makes sence please can someone tell me or point me in the best thing to do to fix it, i wished id left it alone today
Offline leetdi22
Re: Need Help ASAP
« Reply #1 on: June 07, 2011, 09:39:34 pm »
Offline Phil Miller
  • -Given: 86
Re: Need Help ASAP
« Reply #2 on: June 07, 2011, 09:55:00 pm »
Thank you mate your a star, im off to find an empty carpark  :driver:
Offline Phil Miller
  • -Given: 86
Re: Need Help ASAP
« Reply #3 on: June 07, 2011, 10:37:56 pm »
All sorted thank you mate  :notworthy:
Offline leetdi22
Re: Need Help ASAP
« Reply #4 on: June 08, 2011, 09:51:34 am »
happy to help mate
