Author Topic: Spark plug gap should be..?  (Read 12529 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« on: June 08, 2011, 08:56:19 am »
I had my plugs replaced under warranty not long ago. My mileage dropped from 28.5 mpg avg. to 26.5 mpg avg..
I read that on turbo cars that the gap should be tighter, say around .022". I pulled them and adjusted the gap to
.025" and the mileage went up to 28.0 mpg avg.. I'm wondering if, maybe, I should go ahead and pull them out again
and set them at .022", and what has been your experience with this issue?
Offline chris s
Re: Spark plug gap should be..?
« Reply #1 on: June 09, 2011, 12:48:07 pm »
I am about to replace my Plugs as part of my attempt to resolve a mapping issue, and was just going to put in the standard NGK iridium plugs without adjustment.  Although, I've read various posts that the gap is important
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline Boothy
« Reply #2 on: June 09, 2011, 12:51:22 pm »
The NGK ones come pre-gapped for the GTI apparently.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3 on: June 09, 2011, 04:33:27 pm »
Yeah, mine were supposed to be pre-gapped as well. When I pulled them, they were .030 and I adjusted them as I wrote to .025in.
I did notice that the engine immediately ran smoother. Then later that the mileage improved. I'm curious to know if anyone else has set
theirs at .022in and if that setting worked out for you. I have read that others set them at .022in. as that is where they felt the gap should
be set for the 2.0t fsi. I may just go ahead and try it because, not much different right?
« Last Edit: June 13, 2011, 07:23:40 am by ROH ECHT »
« Reply #4 on: June 09, 2011, 05:12:56 pm »
I have to confess that I never gap my NKGs...   :ashamed:
Offline chris s
« Reply #5 on: June 09, 2011, 07:42:21 pm »
Well just put my new plugs in, and didn't change the gap... will see how it  goes now
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Offline Fizgti
« Reply #6 on: June 12, 2011, 06:10:04 pm »
How wud you measure the gap?
Offline Boothy
Offline Fizgti
« Reply #8 on: June 12, 2011, 07:13:30 pm »
Top tip mate pulling mine out later on and check
« Reply #9 on: June 12, 2011, 07:47:49 pm »
If you have ngk iridiums then I advise against trying to physically re-gap them.
Offline Boothy
« Reply #10 on: June 12, 2011, 07:50:29 pm »
Whys that mate?
« Reply #11 on: June 12, 2011, 08:03:39 pm »
The iridium tip is very brittle/fragile so is at risk of damage when trying to regap using a feeler guage.
Offline Fizgti
« Reply #12 on: June 12, 2011, 09:12:09 pm »
Whys that mate?
I never knew anything about re gapping then plugs
