Author Topic: Slight Misfire On Idle  (Read 9574 times)
Offline edition_30
« on: June 08, 2011, 07:08:49 pm »
Since i have owned the car i have noticed a slight misfire on idle. Does not effect performance but just wondering what could be causing the issue.
Plugs were changed as part of 4th year service
Re: Slight Misfire On Idle
« Reply #1 on: June 08, 2011, 07:15:37 pm »
coil packs??
Get it logged with vcds to show what cylinder misfire is occuring and swap the coil pack from a cylinder that's not misfiring. If the misfire follows the "bad"coil pack then buy a new one.
Offline edition_30
« Reply #2 on: June 08, 2011, 10:32:30 pm »
Thanks buddy
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #3 on: August 15, 2011, 10:23:49 pm »
coil packs??
If it's not the coil pack...then what else should one check?
« Reply #4 on: August 15, 2011, 10:48:10 pm »
Could be a faulty injector if plugs and coil packs are ok.
Offline chowgar
« Reply #5 on: August 16, 2011, 11:48:31 am »
will a misfire always throw up a light on the dash?
 I seem to have a slight stutter sometimes on acceleration, coilpacks have just been replaced under recall and I see from the log book the plugs could do with being replaced.... but other than some slight stuttering there are no warning lights on the dash?
this seems to be a common occurance at the moment alot with those that have just had their CP's replaced under recall???
« Reply #6 on: August 16, 2011, 12:15:55 pm »
I've just changed all  4 coilpacks as I had a misfire on cyl3
Still spluttered a bit under load on the way home from work last night
and hiccup'd on idle still.
Plugs were only changed a few thousand miles ago.  It's chewing through plugs!
Ordering another set today, bloody thing  :fighting:
Cyl4 continues to get alot of moisture in the 'coilpack hole'
WILLZIE
« Reply #7 on: August 16, 2011, 12:22:52 pm »
CP Recall???
« Reply #8 on: August 16, 2011, 12:28:17 pm »
l
CP Recall???
Revised coilpacks ending 'F' I think
Offline FamilyDub
  • ...who needs a diesel?
« Reply #9 on: August 16, 2011, 02:16:43 pm »
There are more things that could cause it and i've had all of these :confused:
* Do you still have a diaphragm-type diverter valve?  Change for piston-type 'Revision D' valve, part 06H 145 710 D?
* You've changed the coils - have you changed the sparkies?
* When was the last time you gave your car an 'Italian tune up'?
* Using the correct grade of fuel? 98+ RON?
* Is it 'hunting' for revs, i.e. dropping to 600, then peaking up to 1,500-2,000 rpm?  PCV might be kaput...
Hope you get it fixed.
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
« Reply #10 on: August 16, 2011, 02:29:36 pm »
Useful reminder of the basics thanks  :happy2:
Italian tune up? lol  - thrashing??
Offline FamilyDub
« Reply #11 on: August 16, 2011, 02:48:46 pm »
I wouldn't use the word 'thrashing'...    how about...  'sustained sporty driving', as the VW sales brochures call it! :laugh:
« Reply #12 on: August 16, 2011, 02:51:09 pm »
Sorry, spirited driving....  :innocent:
Offline FamilyDub
« Reply #13 on: August 16, 2011, 05:04:37 pm »
That's the one.  :driver:
